  3. ADE Verifier Datasheet Generation
  • Views 12936
LukiLeu
LukiLeu over 5 years ago
We set up an ADE Verifier view with multiple simulations from other ADE Assembler views. We now want that the verifier automatically creates the datasheets for all these simulations. For this we enabled the option "auto-create all enabled reports". When the verifier is run, it creates the folder "assembler_datasheets" with subfolders for each "implementation cellview". However, no datasheets are generated in these folders. Do I need to enable the datasheet generation elsewhere?
We are using IC6.1.8-64b.83. We already tried to generate the datasheet manually in each of the assembler views and then look that hierarchy item and select that hierarchy item in verifier. However, that did not help. Or is datasheet generation not supported when runplans are used?
    I did a quick search to see if this was a known issue, but to be honest I don't have time today to try this out to be sure. Given that there was a fairly major overhaul of Verifier for the IC6.1.8 release…
    I did a quick search to see if this was a known issue, but to be honest I don't have time today to try this out to be sure. Given that there was a fairly major overhaul of Verifier for the IC6.1.8 release, and you're using the initial "base" release of the tool, I would suggest that it would be sensible to update to the latest hotfix (IC6.1.8-64b.500.15) and see if the problem remains. If it does, please contact customer support.
  • LukiLeu
    LukiLeu over 5 years ago in reply to Andrew Beckett
    I was now able to test the feature in a newer version and I can confirm that the problem does no longer exist.
