  3. Way to set the expression spec to find equal value in ADE...
  • Views 14259
Way to set the expression spec to find equal value in ADE XL
sidm
sidm over 5 years ago
Hi All,
I am trying to evaluate a large number of expressions to see which of them equate to the value "2".
Can anyone please suggest what will be a good way to set the SPEC of the expressions so that I get Pass (Green color) in the output only when the expression evaluates to "2" else fails ??
I couldn't find an "equal to" expression in the drop down as shown below.
regards
    Most measurements return a floating point number, so exact checks are something that would rarely make sense. If they are integer, then it would be reasonable to just set it up as a "tol" spec, with 2 as the first value and (say) 1 or 0.1 (1% or 0.1% tolerance).
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    thank you very much Andrew, this workaround will also work for me.
