  3. Licensing time occupies 70% of simulation time
  • Views 12369
Daniel Bubu
Daniel Bubu over 5 years ago
I am running a simulation using for loop in an ocean script.
I found that around 70% of my simulation time was spent on getting the license.
Is there any ocean command that can hold the license until end of my simulation?
(to minimized licensing time to speedup)
    There's no mechanism for holding onto a simulation license, but depending on what you are doing in your loop, it maybe that the simulator doesn't need to exit between points. Without knowing the details of what you're doing, it's hard to say - and also without knowing the details of your licensing setup - it may be possible to optimise that too.
    I'd suggest you contact customer support so that we can give you some more specific advice.
