  3. Release of license from suspended Monte Carlo+APS
  • Views 3674
jehh
jehh over 5 years ago
We have a setup, where jobs are send to an LSF (running SGE). We then manage licenses for simulations on a priority based system. However, we are experiencing some troubles with Monte Carlo runs specifically.
We have tried and tested suspending APS aps++ jobs, Spectre X jobs and regular Spectre jobs just fine. The jobs are suspended, and licenses released. However, with MC runs, the job is effectively suspended, however it doesn't release the licenses?
Is there some option, like the lsuspend that needs to be set? I've tried debugging quite a bit, but unsucessful, and I am at a dead-end in terms of more debugging.
We are running IC6.1.8, and Spectre 20.1
BR,
Christian
    Hi Christian,
    Are you seeing the +lsuspend or +lsusp argument in the command line if you look at the Spectre log file? In current versions, you have to set this via Setup->Environment on each test - we're adding the ability to override it centrally if preferred, but that's coming in a later IC6.1.8 ISR (ISR17). So for now, it's stored in the test setup, so you need to check that it's enabled.
  • jehh
    jehh over 5 years ago in reply to Andrew Beckett
    I've tried to figure out the exact spectre call MonteCarlo makes, I assume it is found under **/path/to/maestro/result/test_name/**/groupRunDataDir/psf/spectre.out? In the beginning I do see the +lsusp, as I would expect (we've set it from an environmental variable).
    C+P from the log file:
    Command line:
        /usr/pack/spectre-20.10.068-cgh/tools.lnx86/bin/spectre -64  \
            input.scs +escchars +log ../psf/spectre.out -format psfxl -raw  \
            ../psf +aps +lqtimeout 0 +lqmmtoken -maxw 5 -maxn 5 +lorder  \
            MMSIM +lsusp -env ade -ahdllibdir  \
            /**savepath redacted**/maestro/results/maestro/MonteCarlo.11/sharedData/lscsJob120/ahdl/input.ahdlSimDB  \
            +logstatus
    Andrew Beckett over 5 years ago in reply to jehh
    That's odd then. I can't think why this wouldn't work - I would suggest you contact customer support. There are sometimes some DRM-related settings to ensure that suspending a job in your DRM system (SGE in this case) uses SIGTSTP rather than SIGSTOP to suspend the job, but I'd expect that to be the same for all jobs, not just Monte Carlo.
  • jehh
    Thank you, I will gather some minimum viable replicable problem, and contact customer support,
    Small note - the suspension is handled by a script on the grid, and it is specified to use SIGTSTP only, so I doubt this is the case.
