  3. PSPICE model simulating in cadence virtuoso
  • Replies 19
  • Views 33624
robert 21
robert 21 over 5 years ago
Hello,After working for a long time in cadence virtuoso ,I got a task of implementing a circuit on PSPICE.
Its like going to the STONE age.
My cadence virtuoso is on linux server ,my SPICE model of MbreakN is
.model Mbreakn NMOS VTO=1 LAMBDA=0.025 KP=0.05m W=2.5u L=0.25u
How can i create a SPICE model from the cadence virtuoso menu?
Thanks.
    ShawnLogan over 5 years ago in reply to robert 21
    Dear robert21,
    robert 21 said:
    DO i need to specify the filename as shown in the form?
    If yes then do i need to press also load save or CDF dump?
    Did you happen to read Andrew's first comment to you where he stated:
    Andrew Beckett said:
    if you want to use a PSPICE model, then you can use (in ADE) Setup->Simulation Files->PSPICE files and specify the file containing the model above. Then in the schematic, you could just place an analogLib/nmos4 and specify the model name as Mbreakn.
    However, you said "How can I create a SPICE model from the cadence virtuoso menu". I don't really know what you mean by
    The path to the filename containing the model is placed in the Simulation Files GUI under the PSPICE heading. If you hit the "Help" button on the CDF form you shown, it will cldarly indicate what the function of the "File Name" entry is. I include my copy below. I think you should consider exploring the "Help" button as it covers all the questions I think you asked.
    Shawn
    Andrew Beckett over 5 years ago in reply to robert 21
    robert 21 said:
    Hello Andrew, to my defence i showed an attempt to create PSPICE file,you said its the wrong way
    Yes, because I'd already said how to do it, and then you picked a completely different way.
    You seriously need to read what I've said. If you had needed to specify the file name on the form for the model, then I'd have told you that. Given that this file name field is for loading and saving the CDF, it's clearly not for that.
    I have repeatedly stated that for "Cadence" to know where the file is, you specify it as a PSPICE File on the Setup->Simulation Files form in ADE. I even surrounded it in red a few steps ago in the thread to make it crystal clear.
    You're doing a very good job of eliminating any patience I had to answer this or any of your questions. I should have remembered this lack of attention to instructions you're given from previous threads (sorry if this seems rude, but I answer here in my spare time, and this has used rather more of my spare time than it should).
    This really is a simple process which you seem to be doing an amazing job of getting wrong at every step.
  • robert 21
    robert 21 over 5 years ago in reply to Andrew Beckett
    Hello Andrew,Thank you very much for the patience.
    I have filled the form like you said.then i tried to run simple DC simulation as shown bellow
    also i included the file of the ckt as shown bellow.
    Why it gives me this error?
    Thanks.
    I've no idea. It would help if you gave the entire log file rather than a picture of part of it, and ideally the whole input.scs. The log file will then also show what exactly was read, plus the simulator version used.
    I did wonder whether it might be because of the mixed-case of the model name; PSPICE is a case-insensitive language and Spectre is case-sensitive, but it works for me. Perhaps try changing the model name in both the file and the CDF to "mbreakn" (all lower case) just to play safe. However, I did not have to do this with SPECTRE19.1 for example.
  • robert 21
    Hello Andrew ,Yes i worked
    I ran DC simulation but there is no gm or region parameter in the list describing the OP as shown bellow.
    Why i cant see that on cadence?
    That's because you are annotating Model Parameters and not DC Operating Point parameters. gm is not a model parameter, so that's why it doesn't show there. If you'd picked DC Operating Point as the Display Mode then it would appear in the list (along with region).
    Andrew Beckett over 5 years ago in reply to Andrew Beckett
    Can you please stop posting questions and then deleting them afterwards? This is really annoying. I see the email in my mail inbox, look up a relevant answer, and then go to post it only to find that you've deleted it. This has happened more than once on this thread.
    Better to post another response saying that you've resolved it if that was the reason for you deleting it. I was going to point to this post - you'd need to add further cdsParam() labels on the symbol (e.g. cdsParam(4), cdsParam(5) etc - you'd copy the existing label and change the number in parenthesis (the deleted question for anyone else who was following this thread was about adding more than 3 operating point parameters).
  • robert 21
    Hello Andrew ,no i didnt solve it,sorry wont happen again.
    "to add further cdsParam() labels on the symbol (e.g. cdsParam(4), cdsParam(5) etc - you'd copy the existing label and change the number in parenthesis"
    As you can see in the printscreen bellow,i have tried to copy paste one lable to create a copy but there is no such option when i do right click ,as shown bellow.
    Where did i go wrong?
    Thanks.
    Sorry, I thought you'd used Virtuoso before. Virtuoso does not have a copy/paste paradigm - copying in the symbol is the same as it is in the schematic and layout editor. Use the Edit->Copy menu from the Edit pulldown at the top of the window. Either pre-select the label to copy, or if nothing is selected it will prompt you to select something. Following the prompts shown in the bottom of the window.
