  3. PSPICE model simulating in cadence virtuoso
  • Replies 19
  • Views 33609
robert 21
robert 21 over 5 years ago
Hello,After working for a long time in cadence virtuoso ,I got a task of implementing a circuit on PSPICE.
Its like going to the STONE age.
My cadence virtuoso is on linux server ,my SPICE model of MbreakN is
.model Mbreakn NMOS VTO=1 LAMBDA=0.025 KP=0.05m W=2.5u L=0.25u
How can i create a SPICE model from the cadence virtuoso menu?
Thanks.
    As is covered in numerous posts on this forum, if you want to use a PSPICE model, then you can use (in ADE) Setup->Simulation Files->PSPICE files and specify the file containing the model above. Then in the schematic, you could just place an analogLib/nmos4 and specify the model name as Mbreakn.
    However, you said "How can I create a SPICE model from the cadence virtuoso menu". I don't really know what you mean by "create" here. Please clarify (perhaps you mean use rather than create?)
  • robert 21
    robert 21 over 5 years ago in reply to Andrew Beckett
    Hello Andrew,
    my spice for NMOS is as follows
    I have tried to do the following steps,but i dont know what to do with the pins of the circuit
    Were is the drain,source,gate in there?
    Thanks.
      s
    Andrew Beckett over 5 years ago in reply to robert 21
    Creating a PSPICE view doesn't make any sense here, since that's really for SUBCKT models, and this is not a SUBCKT model - it's a direct .MODEL card.
    So use the approach I suggested - it's similar to how spectre models are done (you can of course create your own transistor symbol, but probably simplest to start by copying the nmos4/pmos4 with all the views, and you can always change the CDF in the copy to have the model name specified by default in your copy.
  • robert 21
    Hello Andrew,I have copied NMOS4 from analoglib as shown bellow,but where do i put my  line?
    Thanks.
    Put it in a text file somewhere (it doesn't live within the libraries), e.g. with a ".psp" or ".ckt" suffix (it really doesn't matter, but I wouldn't use .scs) and then reference it from (as I keep saying) from Setup->Simulation Files->PSPICE files in ADE. Spectre model files also don't live in the libraries - it's similar in that respect to how spectre model files are usually referenced (they are normally referenced via Setup->Model Libraries).
    This really is not that complicated...
  • robert 21
    Hello Andrew ,I have created the following file shown bellow .
    I tried to look for the SETUP in library manager and in schematics ,and in the starting window which rises after virtuoso command
    Were is it located vissualy?
    Thanks.
    I give up. Why do you keep doing something different from what I'm telling you to do?
    You've now added another line into the file with an instance of a transistor. Why? You posted earlier on something about needing to specify the "leg" order (you don't - MOS models are defined to be D G S B, and the CDF for the component ensures that the netlist is produced in that order). You then deleted that post so I couldn't answer.
    I keep telling you that you reference this file in the Analog Design Environment. It's NOT in the library manager, or from the "starting window" (CIW).
    Just to reiterate the same thing (again), it's here:
  • robert 21
    Hello Andrew,I have added the path of the PSPICE file like you said in the ADE explorer.
    "simplest to start by copying the nmos4/pmos4 with all the views, and you can always change the CDF in the copy to have the model name specified by default in your copy"
    I have copied the NMOS4 fileas shown bellow in the printscreen.
    how i connect the .ckt file with this  symbol?
    If i understood you correctly.
    Thanks.
    As I said in my very first reply:
    If you want this to be done by default for each instance of the transistor, you'll need (as I also said before) to edit the CDF for the component. I was assuming (since it's quite key to the use of Virtuoso) that you knew how to do that or could read the documentation to figure out how if you didn't. Or maybe read one of the many posts on this forum. Failing that, here's a step-by-step guide:
    1. Go to Tools->CDF->Edit in the CIW
    2. Ensure that the "CDF Layer" is set to "Base" (otherwise it doesn't get saved on disk)
    3. Fill in Library Nanaame as neww (your library name)
    4. Fill in Cell Name as nmos4 (your component name)
    5. Find the row in the Component Parameter tab with "model" as the Name. Click on that row
    6. In the box at the bottom of the form labelled Default Value enter Mbreakn (your model name)
    7. Press OK on the form
    I didn't think it was necessary to show screenshots of all of this, hopefully it's clear enough this time.
  • robert 21
    Hello Andrew, to my defence i showed an attempt to create PSPICE file,you said its the wrong way :-)
    regarding your steps
    I have updated the model to be Mbreakn as you said and shown bellow.
    Also Ifilled the form as you showed,except one thing,which is the File name section.
    DO i need to specify the filename as shown in the form?
    If yes then do i need to press also load save or CDF dump?
    How Cadence will know from where to take the Mbreakn model?
    Thanks.
