  3. Difference between pnoisemethod=default and pnoisemethod...
  • Views 1187
Difference between pnoisemethod=default and pnoisemethod=fullspectrum?
charlieWu
charlieWu over 5 years ago
Hello everyone,
I ask a question here last week and get great help , and I  have another question after simulating. I read the guideline "Using Spectre RF Analyses for Non-RF Circuits", which is shown as below:
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O0V000009ESBAUA4&pageName=ArticleContent
page 20 of the note says "Select fullspectrum method. This option eliminates the need to tune the maxsidebands option", but simulation results are the same no matter that I use pnoisemethod=default or pnoisemethod=fullspectrum.
I did another test that giving different "maxsideband"(based on noisefmax setting in transient noise simulation) value when I use "pnoisemethod=fullspectrum", and output integrated noise will become larger when I give a bigger maxsideband(it makes sense to me).
I can't find the description about the relationship between "fullspectrum method" and  "maxsideband" in spectre manual.
My question is simple: Should I use "pnoisemethod=fullspectrum"?  I think it is more reasonable for me that ignoring  pnoisemethod=fullspectrum and  give an appropriate maxsideband now.
