  3. Simulating 4 bit sequence in one simulation
  • Views 16971
sidm
sidm over 5 years ago
Hi All,
I am simulating a setup with AC analysis and need to vary 4 bits. As of now I am changing the signal bits one at a time to go through all the 16 possible combinations and simulating the setup after each sequence of the bit followed by plotting the voltage at the output node.
Is there a way I can simulate all the 16 combinations of the 4 signal bits in one simulation and get the voltage plot on the output node for all the 16 bit sequences ?
I am using ADE-L and IC 6.1.8
    You could simply have four voltage sources on each of the signal bits, and create a variable for each. Then in the Tools->Parametric Analysis (if you insist on using the old ADE L) or in the design variables themselves in ADE Explorer, you could set each to sweep the two value 0 and 1.2 (or whatever the high voltage is) and then you'd end up with 4 nested sweeps of two value giving you 16 combinations total.
    Or you could use the bussetp component from Creating a component that allows setting a value on a bus in an analog simulation and then put a single design variable on that and sweep that (via parametric analysis or ADE Explorer sweep) from 0 to 15 in steps of 1.
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    thank you very much for the reply Andrew ,
    I am using a port for the 4 bit input signal in the schematic and 'don't have voltage source for this 4 bit signal .This port drives the net d_en_hv<0:3>
    In the ADE-L i am setting the stimuli on these 4 bits as shown below :
    Do I still need to use separate voltage sources for all the 4 bit variation ?
    thanks
    Andrew Beckett over 5 years ago in reply to sidm
    Yes, you can do this with the old ADE L stimulus editor. Rather than setting them all to 1.8, set them to en_hv_0, en_hv_1 etc (i.e. a variable name unique for each bit), and then in the Variables->Edit create four variables called en_hv_0, en_hv_1 etc, with values of 1.8. Then you can sweep each of these four variables from 0 to 1.8, set the Step Mode to Auto and the Total Steps to 2 (other ways would achieve the same thing).
  • sidm
    Thank you very much Andrew.
