  3. Over-riding default value of the simulation folder path...
  • Replies 7
  • Views 19396
Over-riding default value of the simulation folder path in Assembler and Explorer.
sidm
sidm over 5 years ago
Hi All,
I am using a maestro view setup in which the simulation folder path is set to ~/simulation which is the default setting.
I change it manually to ./simulation to avoid space issues.
But after restarting Virtuoso session this setting again reverts to ~/simulation
Is there a way to permanently set the simulation folder path to ./simulation for the maestro view ?
    Put this in the .cdsinit :
    envSetVal("asimenv.startup" "projectDir" 'string "./simulation")
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    thanks Andrew,
    if I share the workspace (as .tar.gz) with colleagues after including these changes in the .cdsinit will they see the changes after unzipping the workspace tarball ?
    thanks
    Andrew Beckett over 5 years ago in reply to sidm
    Assuming the .cdsinit is also in the tarball, then yes. The setting is not stored within the maestro view - it's an environment setting rather than something just used to seed the ADE setup before being saved in the view.
  • sidm
    thanks for the confirmation Andrew. This is very helpful.
    One of the reasons I am trying to set the simulation directory to ./simulation so that the path to the s-parameter files being referred to inside the nport blocks doesn't break when the workspace is shared.
    For some of the cells using nport I am using relative path for the s-parameter file  like $PWD/../../../../../abc.s2p
    Where $PWD is read by the tool as the simulation directory path all the way up to netlist folder
    Perhaps you can suggest a better way to refer to workspace local s-parameter files such that the simulation doesn't fail on account simulator not being able to find the file.
    Though it is present inside the workspace but has been unzipped on a different machine.
    Yes, a better solution would be to not use a full path on the nport. Specify it as "abc.s2p" (without the directory component) and then use Setup->Simulation Files->Include Path in ADE and set that as "." or "./sparamDir" - i.e. the directory relative to the working directory where your s-parameter files are stored. ADE automatically takes care of converting this path relative to Virtuoso's working directory (if "." is used) into the full path to be passed to spectre on the command line via the "-I" argument (include path). Spectre runs with its working directory as the netlist dir, and looks for any non-local files along the include path passed to it.
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to sidm
    In the latest Virtuoso releases, you can also store the S-parameter data in a cellview. In this case, you don't even need to specify an include path (see pages 19-20 of https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000ADvLMEA1).
  • sidm
    thank you very much Andrew.
