  3. VIVA background color
  • Views 16995
jorgevdelacruzN
jorgevdelacruzN over 5 years ago
I'm currently using virtuoso ICADVM18.1-64b.500.10 and I just realized that I can't change the viva background as in previous versions. When I right-clicked on the viva background and the Graph properties(general tab) pop-up,  the option for the background colour is not available. Also, Another way I changed the background was using the command envSetVal("viva.rectGraph" "background" 'string "white"); but now this way is also not working.
Is there a way to change the viva background colour or CADENCE remove this option for the newer versions?
Thanks in advance
    envSetVal("viva.graphFrame" "background" 'string "white")
    is the setting from IC6.1.8/ICADVM18.1 onwards. This is a consequence of how flexible sub windows work.
  • jorgevdelacruzN
    jorgevdelacruzN over 5 years ago in reply to Andrew Beckett
    It worked. Thank you
