  3. SKILL GUI
  • Subscribers 136
  • Views 17718
SKILL GUI
Pedro P
Pedro P over 5 years ago
I would like to create a GUI that would be able to display the list of pins that belong to a symbol and to be able to sort/categorize then as SUPPLYs, GNDs, DIGITAL and ANALOG nature.
Then be able to have a button to call an external python script that will use this information to create a customized Verilog code and import that to my library manager.
How difficult is to do such GUI?
Is there any tools / API that will help me to hand draw a GUI that will become SKILL code?
Is there any information that could help me to start doing such GUI?
Or example of what I’ve described?
Thank you
  • drdanmc
    drdanmc over 5 years ago
    Here is a brief outline, hopefully the manual for some of the functions involved will help you fill in the details.
    ;; create a form.  This is a description of what widgets you will have and how they are laid out.  There are different
    ;; styles for how you control arrangement.  I'll show more or less how to do it with layouts.
    myForm = hiCreateVerticalBoxLayout('myForm
          ?items list(
                hiCreateStringField(?name 'countField ?prompt "Enter a Number" ?value "" ?defValue "10" ?callback "myCB('count)" ?editable t)
                hiCreateBooleanButton(?name 'enableField ?buttonText  "Enable something" ?value nil ?defVale nil ?callback "myCB('enable)")
                ;; others may be hiCreateIntField(), hiCreateFloatField(), hiCreateButton()
                hiCreateReportField(
                     ?name 'pinsField
                     ?title "Pin results"
                     ?titleAlignment 'center ;; 'left, 'center, 'right.
                     ?headers list(
                           list("Pin Name" 100 'left 'string t)
                           list("Pin Direction" 100 'left 'string t)
                           list("Signal Type" 100 'left 'string t)
                    ?choices nil
                    ?callback nil
                ) ; report
            ); items
    ) ; form
    ;; create the form from the layout
    hiCreateLayoutForm( 'myForm
    ?buttonLayout 'Close
    ?initialSize list(600, 800)
    ?minSize list(w, 400)
    ?maxSize list(2000, 5000)
    ?sizePolicy 'expanding
    ;; add tooltips
    myForm->countField->hiToolTip = "some tooltip"
    ;; actually display it
    hiDisplayForm('myForm)
    Hope this gets you moving in the right direction.  If you look up hiCreateBoxVerticalLayout that will get you in the right section of the manual.
    ShawnLogan over 5 years ago in reply to drdanmc
    Dear Pedro P,
    In addition to drdanmc's very helpful answer, the following Cadence On-line support URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000002JdnmEAC&pageName=ArticleContent
    contains links to a SKILL programming tutorial (in both PowerPoint and Adobe Acrobat formats) as well as a tar file containing its lab exercises.
    Maybe you know this much about SKILL and its use in the Cadence tools already, but I was not sure based on your request and thought I should at least pass it along...
    Shawn
