  3. IBM/GF bicmos8hp corner setup
  • Views 829
teatea
teatea over 5 years ago
Hello Everyone
we just started using IBM/GF bicmos8hp process. I noticed at least one of you used this process before. I am sure some of you used similar process. I have a question on corner setup if you don't mind: by default, bicmos8hp process has only corners for fet devices(ff, ss, tt, fs, sf, ffs, etc.) how do you setup/customize/accommodate  corners for res, cap, etc.?
Foundry suggested user tune corner params for other devices, the valid values are from -3 to +3. I guess I can set for instance cnr_res to -3 for ss, +3 for ff for instance, how about cor_cap? how about other fet corners what should these cnr paramesters be set to, default formula as shown in the screenshot? please see attached screenshots.
thanks very much
-jasmine
