  3. Liberate RAK - area of cell?
  • Views 1735
hchenji
hchenji over 5 years ago
I was looking at the RAK "Using Liberate to Characterize Standard Cells". I was able to run it and see the .lib file being created from the SPICE netlists and the model. The main script pulls in a user data file "userdata/userdata.lib". This contains the area of each cell.
My question is: if I have to design my own library from a PDK, how does one get the area of these cells and into the correct format? It would help to see the link between Virtuoso or some other tool, and Liberate.
  • Guangjun Cao
    Guangjun Cao over 5 years ago
    The physical area comes from the layout, in square micron.
    you can use set_attribute to add the area (and many other attributes) into a .lib file. Please refer to the manual.
    Guangjun
