  3. spectre alter in MTS environment
  • Views 14609
drdanmc
drdanmc over 5 years ago
Is there any way to tell an alter statement to look for a parameter in the same scope as where the alter statement appears?  For example, suppose I have a really basic model file that includes some alter statements like this:
// myfile.scs
section params
    parameters VDD=3.3
endsection params
section nom
    include "myfile.scs" section=params
    ALT_VDD alter param=VDD value=3.3
    ALT_temp alter param=temp value=27
endsection nom
section slow
    ALT_VDD alter param=VDD value=3.0
    ALT_temp alter param=temp value=125
endsection slow
When I include this in a non-MTS simulation the alter statements work.  But now if I use this as an MTS model file in something like:
// MTS block
subckt tech1_cell IN OUT
    include "myfile.scs" section=nom
    // rest of technology #1 netlist
ends tech1_cell
// MTS block
subckt tech2_cell IN OUT
    include "myothermodels.scs" section=nom
    // rest of technology #2 netlist
ends tech2_cell
ITECH1A (T1INA T1OUTA) tech1_cell
ITECH1B (T1INB T1OUTB) tech1_cell
ITECH2 (T2IN T2OUT) tech2_cell
// rest of technology independent netlist
// spectre analysis statements
I have a problem which is the alter statements in the "myfile.scs" model file run in the top level scope and look for a top level parameter called "VDD" instead of the parameter that is local to the "tech1_cell" scope.  In addition, the temperature change is global and not to the two instances of tech1_cell.  I can't use "sub=ITECH1A" on those alter statements because the model file is not supposed to need to know details about the circuit that uses it and on top of that in this case I instantiated 2 instances of "tech1_cell".
Am I missing some useful keyword that will make it all just work or is this one of the things that MTS sims just don't really support at this time?
    Hi Dan,
    This is a very odd way of trying to achieve this, and not how MTS is intended to work. I don't think there's any expectation that alter (I had a discussion a few years back about altergroup being used in a similar way because of a peculiarity of one customer's models, and that just fails by saying that altergroup can't be used in subckts).
    It could just define the parameter - or set the temperature as an option - rather than doing an alter (you might need to set redefinedparams to allow the redefinition).
    I suggest you contact customer support so that it can be investigated more closely.
  • drdanmc
    drdanmc over 5 years ago in reply to Andrew Beckett
    The dificulty of something like:
    OPT_temp options temp=110
    instead of the alter is that it appears I have to give numeric values everywhere.  So for example, I can't give names to my supply and temperature limits in one section and refer to those everywhere.
    section globals
    parameters temp_hot=125
    parameters temp_nom=40
    parameters temp_cold=-20
    // supply values to follow
    endsection globals
    section nom
    include "myfile.scs" section=globals
    // fails claiming unknown parameter "temp_hot"
    OPT_temp options temp=temp_hot
    // works outside of the MTS context
    ALT_temp alter param=temp value=temp_hot
    // rest of models
    endsection nom
    In a somewhat ironic result, it appears that the scoped options try to resolve the parameter name "temp_hot" in the global context!  Meaning if I define "temp_hot" as a design variable that ends up as a parameter at the top level of the netlist, I can pass that down.  So I could hard code the numbers but it is very nice to have the numeric values contained to a single spot.  Again it appears that the options approach would work outside of MTS but not inside of MTS.
  • drdanmc
    drdanmc over 5 years ago in reply to drdanmc
    The other challenge associated with using `options` instead of `alter` is that in a non-MTS setting, any `options` statements that set temperature in a model file are likely to be overwritten by the `options` statement generated by the netlister.
    I've opened a case with customer support and see if they can dig deeper with me.  Thanks.
    -Dan
    Andrew Beckett over 5 years ago in reply to drdanmc
    Thanks for taking this up with support. I'd love to have tried this out, to make sure I give you a reasoned answer, but unfortunately I don't have the bandwidth or head space to be able to do that this week (or next), so support is the best approach here.
