  3. How to access subckt parameters in sim results?
  • Views 14274
drdanmc
drdanmc over 5 years ago
Is there some particular magic to access a subckt level parameter in the simulation results?  For example:
subckt mycell (OUT)
  parameters VDD=1.8
  V0 (OUT 0)  vsource type=dc dc=VDD
ends mycell
I0 (1 0) mycell
I1 (1 0) mycell VDD=1.5
How can I figure out the value of the VDD parameter either as a "mycell" default, or preferably as an I0 and I1 instance level value?  I see in subckts.info.subckts  that the parameter *names* are in the PSF file.
TYPE
"subckt" STRUCT(
"subckt_params" STRING *
"subckt_terminals" STRING *
"subckt_instances" STRING *
) PROP(
"key" "sub"
but I don't see the *values*.   I'm assuming step 1 is I need to figure out the appropriate save option in ADE to get the appropriate save options into spectre.  Then I need to figure out how to access in ADE/Ocean.
    On the Outputs->Save All form in ADE (mind gone blank - might be Save Options), add a new row for another “info” analysis with “what” set to “allparameters”, name can be what you like and the output should be to rawfile. In this database that results you’ll get the hierarchical path to each parameter - I think exactly what you want.
  • drdanmc
    drdanmc over 5 years ago in reply to Andrew Beckett
    Thanks!   In ADE Explorer it was under Outputs->Save All... to open the Save Options dialog and then:
    That produced the following in the spectre netlist:
    info info what=allparameters where=rawfile
    and, it works as long as there are no string parameters.  If there are string parameters, then depending on the `-format` option on the spectre command line you get crashes.  That is in the psfxl output.  psfascii works.  I'll submit a short test case to customer support.  NOTE:  You can have string parameters no matter the format as long as you don't try to include
    Fatal error found by spectre during info `allParams'.
        FATAL (SPECTRE-7035): unexpected variable length data type: Error detected in psf library while writing to file `allParams.info.allparameters'.
    -Dan
    Andrew Beckett over 5 years ago in reply to drdanmc
    Dan,
    Ah, yes. The data is actually in psfbin format (even if you pick psfxl), and I see that it does suffer from this. I'd not checked it with string parameters... I didn't find any reports on this either, so I suspect that it's not common for people to enable saving of what=allparameters or if they do, they don't have any string parameters.
    If you can let me know the case number after filing it, I'd like to follow it and chat with R&D about it too.
  • drdanmc
    case 46505710
    I included a couple of short netlists as well as well as a wrapper script to run through the various cases.  It would actually be nice to have a depth limit on that too.  In my particular case I really only wanted to find the parameters just 1 level down.
    Thanks!
