  3. Skill code for identifying all paths in the design
  • Replies 11
  • Views 18079
sidm
sidm over 5 years ago
HI All,
I need some help on skill program. Will be helpful if anyone can point me to something that can do the following :
1. Open the layout cell view
2. Query the cellview to iterate over all the shapes in the layout design and note all the shapes that are of type = Path or Pathseg
3. If the shape is of type = Path or Pathseg then get the pointlist corresponding to this shape.
any pointers will be great help.
thanks
    ShawnLogan over 5 years ago
    Dear sidm,
    Did you happen to search on-line support?
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000002JdnmEAC&pageName=ArticleContent
    It provides links to an Adobe Portable Document and PowerPoint file with a tutorial and lab exercises. A link to a tar file with the exercises is also provided. Sample SKILL codes are provided at On-line support articles:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od000000051iK
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009xxXdEAI&pageName=ArticleContent
    and the very recent sample GUI  SKILL code (with the same Cadence link I later added)  to get you started that was just posted.
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/47494/skill-gui/1372583#1372583
    Shawn
  • sidm
    sidm over 5 years ago in reply to ShawnLogan
    thanks for the reply Shawn, yes I have looked at these material before but if there is a sample code resembling my requirement that will be more helpful. (or atleast a code snippet looping over all the shapes in the cell view to get their pointlist).
    Andrew Beckett over 5 years ago in reply to sidm
    Off the top of my head (I didn't test this) - just printing the output because you didn't make it clear what you wanted:
    procedure(CCFdoStuffForSIDM(lib cell view)
      let((cv pointList)
        cv=dbOpenCellViewByType(lib cell view)
        foreach(shape cv~>shapes
          pointList=
            case(shape~>objType
              ("path" shape~>points)
              ("pathSeg" list(shape~>beginPt shape~>endPt))
          when(pointList
            printf("%s: %L\n" shape~>objType pointList)
        dbClose(cv)
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    Thank you very much Andrew , I need to delete all the path and pathsegs in the cellview after scanning the layout design and replace them with a newly drawn path using the pointlist derived earlier from the previous instance of the path/pathseg (that needs to be deleted).
    The width and pointlist derived from the original path has to be reused to construct the new path with another function. Then delete the old path.
    something like :
    cp = list(pointlist from original path/pathseg)
    newpath = Fn(cp old_path_width)
    delete_old_path
    I need to ensure that the code can be run on IC618 and later versions.
  • sidm
    sidm over 5 years ago in reply to sidm
    HI All,
    In continuation to the previous query , what will be a good command to delete the old path and pathsegs after getting the point list from them ?
    thanks
    Since you edited your previous post after sending it, I didn't see the edited version above; I chose to delete the email notification because it didn't have any further questions in it. I though it was a particularly odd requirement, but so be it. I still don't understand why on earth you'd want to delete all the paths/pathSegs and then recreate them. I'll leave that as an exercise for you - I have a horrible feeling that this will just be a creeping set of imprecise requirements, so that's why I'm not going to attempt to write the whole code because I don't really know what you want. Presumably you'd also want to keep the layer information, width, end information - it's likely to be far more than just the width and the point list.
    To delete the original shape you'd use dbDeleteObject(shape)
  • sidm
    thanks Andrew,
    The width and pointlist derived from the original path has to be reused to construct the new path with another function. Once this function creates the new path the old one can be deleted.
    Yes I need to take care of the lpp as well as endstyle as well.
  • sidm
    Will the below code that you had shared earlier also take care of hierarchical layout designs / cell views ??
      let((cv pointList)
          pointList=
            case(shape~>objType
          when(pointList
        dbClose(cv)
    thank you
    ShawnLogan over 5 years ago in reply to sidm
    Dear sidm,
    II think Andrew's pseudocode was in response to your original request, which was:
    Hence, I believe his code is for shapes in the cell view you have open. Niote the foreach() argument. I don't see anything in the code that will descend into a shape and find paths within it. Do you?
    I might suggest if you used his code, you simply try it to save Andrew some time. He answers a tremendous number of questions - and I see you have posed more questions in your posts for him before he has even had time to provide any insight into the prior questions!
    Shawn
  • sidm
    I have tried the suggested code and it is fine for flat cells but yes I have not been able to make it work with hier. Designs hence I asked this query as I am not an skill code expert. So i thought of confirming the same.
    There is no urgency to answer but will be helpful if some solution can be suggested for hier. Designs by Andrew whenever he has time.
