  3. Pre modification of job policy based on MMSIM requireme...
  • Views 13661
Pre modification of job policy based on MMSIM requirements
jehh
jehh over 5 years ago
We have a setup today, where a script running on our LBS (SGE) can suspend jobs on the bulk queue, if licenses are required on a priority queue.
Today, the individual designer has to adjust the requirements field in the job policy such that the required mmsim licenses are known to the script on the SGE.
However, from time to time, a designer might accidentally 'block' many/all licenses on the SGE, due to a mismatch between the requirement field in the jobpolicy and the actual usage.
Is there an 'easy' fix, where the jobpolicy can be automatically adjusted based on the MMSIM requirements?
Or do I need to do a deep dive on some pre-simulation SKILL code that runs a license-check and adjust the job-policy?
BR,
Christian
    Hi Christian, Since the job is started before the simulation has, it's quite difficult (without a lot of code) to set the job policy dynamically based on the needs of the simulation. Instead, my recommendation…
     Hi Christian,
    Since the job is started before the simulation has, it's quite difficult (without a lot of code) to set the job policy dynamically based on the needs of the simulation. Instead, my recommendation would be to instead have APS/Spectre X inherit the resource requirements from the distributed resource management system's resources.
    For example, on the High Performance Simulation options, specify the number of threads as "farm" (or "sge" or "lsf" - but "farm" caters for both) and it will then inherit whatever number of CPUs has been allocated to the job.
    Otherwise it's a bit of a cart-before-horse problem - you don't know the resources that the simulator needs until it's started. That said, with ADE Assembler the Job Setup form has a "Resources" tab which can be used to try to identify likely resources based on a trial run or on previous simulations. More information  can be found by pressing the Help button on this form.
  • jehh
    jehh over 5 years ago in reply to Andrew Beckett
    Thank you, this helps a lot! A quick follow up question: Is it possible to setup this up in the .cdsinit?
    BR.
    Andrew Beckett over 5 years ago in reply to jehh
    You could certainly set the default behaviour for new tests by setting:
    envSetVal("spectre.turboOpts" "numThreads" 'string "farm")
    envSetVal("spectre.turboOpts" "spectreXNumThreads" 'string "farm")
    that won't affect existing tests though.
