  3. accessing simulation temperature in a DC temperature sw...
  • Views 14763
accessing simulation temperature in a DC temperature sweep
DrJoerg
DrJoerg over 5 years ago
I am doing a temperature sweep dc simulation. For a calculation in the output setup tab, I need to access the temperature (as an independent variable) for that simulation point.
How can I do this?
Jörg
    Jörg,
    You need to use the xval function on a waveform from the dc sweep - this will give you a waveform with the independent variable versus itself. So for example:
    xval(VS(“/out”))
