  3. spectremdl mvarsearch lm method?
  • Views 12256
yeh1
yeh1 over 5 years ago
Does the spectremdl mvarsearch option "method = `lm" work? In my sims it seems mvarsearch always uses `newton method.
The mdlref.pdf says (spectre version 17.1):
method:
The method to be used in the algorithm method. Possible values
are `newton (newton solver) and `lm (levenburg marquardt).
While `newton is faster than `lm, `lm has more robust
convergence properties. You should use `newton only when
init_val values are close to the final solution and you want a
faster optimization.
`newton assumes that the number of param_statement=number of zero_statement. If this is not true, mvarsearch automatically changes method to `lm.
Default value: `lm
    I just tried it and it's using 'lm mode by default (at least in the latest SPECTRE19.1 and SPECTRE20.1 ISRs). I compared the iteration information by saving stuff with an MDL print statement, and if I specify method='lm then I get the same results as default, whereas if I specify method='newton it takes more iterations.
    Which spectre version are you actually simulating with, and why do you think it's always using the newton method? As far as I could see, this doesn't seem to be recorded in the log files anywhere (maybe I was looking in the wrong place).
