  3. Schematic Bus Signal only every nth net
  • Views 14204
patschouly
patschouly over 5 years ago
Is there a way to access only every nth value of a bus with a simple expression? E.g. I have a schematic with a bus pin (<32:1>) and I would like to have a net with <32>, <28>, <24> etc. Can this be done with a simple single expression?
Kind regards,
Patrick
    Patrick,
    Add a wire label of either <32:1:4> (or <32:4:4>) or mybus<32:4:4> if you want to specify the bus prefix on the wire. The first will just tap off every 4th bit from the bus. The final number (after the second colon) is the increment. See <ICinstDir>/doc/comphelp/comphelp.pdf - and look in the Connectivity and Naming Conventions chapter.
