  3. How can I get equivalent circuit of BSIM-BULK model
  • Views 15224
yysunj
yysunj over 5 years ago
I am simulating BSIM-BULK model using Verilog-A code of BSIM-BULK model, now.
However, I do not get a equivalent circuit of BSIM-BULK model, yet.
How can I get a equivalent circuit of BSIM-BULK model?
Thank you
yysunj
    ShawnLogan over 5 years ago
    Dear yysunj,
    This makes sense. You are able to simulate the circuit using a veriloga (i.e., behavioral) view of a BSIM_BULK model.
    However, then you write:
    Are you suggesting the response you are getting is not the response you expect with the verioga view of the BSIM-BOLK veriloga model?
    Are you instead suggesting you want to get some other type o model of a BSIM_BULK device (other than veriloga model)?
    To me anyway, I am afraid I am still not clear on both your problem and your request. Sorry.
    Shawn
  • yysunj
    yysunj over 5 years ago in reply to ShawnLogan
    For example, equivalent circiut of Poly-Si TFT model is Figure 1
                                        (Figure 1. Equivalent circuit of Poly-Si TFT model)
    I want a model of this type. (I want equivalent circuit of BSIM-BULK model)
    Could you please tell me how to get it?
    Thank you
    yysunj
    ShawnLogan over 5 years ago in reply to yysunj
    Dear yysunj,
    From your UNIX prompt, typing:
    $ spectre -h bsimbulk | more
    Device bsimbulk
    bsim6 model (Also known as bsimbulk, for more information, please refer to the BSIM6/BSIM-BULK
    Model chapter in the Spectre Simulator Components and Device Models Reference manual. )
    The model parameter "version" accepts only a real number value, such as 6.00 for version=6.0.0.
    The available versions for the bsim6 model are 6.00(6.0.0), 6.10(6.1.0), 6.11(6.1.1)
    106.2(Bsimbulk 106.2.0) and 107.0(Bsimbulk 107.0).
    Sample Instance Statement:
    m1 (0 2 1 1) pchmod w=2u l=0.8u as=250p ad=250p pd=168p ps=168p m=1
    will provide guidance on utilizing the built in spectre model of a BSIM BULK device. I have attached the full context of the command. A reference to the Cadence manual that contains its definition is also provided.
    I hope I understood your request this time.
    Shawn
    bsimbulk.txt
    The usual place for this kind of information (for built-in models) is the Spectre Circuit Simulator Components and Device Models Reference (<SPECTREinstDir>/doc/spectremod/spectremod.pdf), however for bsim6 (aka bsimbulk) there is no equivalent circuit shown in the documentation. This is because it is based on the documentation from the BSIM group at Berkeley, and their documentation also doesn't include an equivalent circuit.
    You probably will need to contact the BSIM group at Berkeley for this (they are the authors of the model): http://bsim.berkeley.edu/models/bsimbulk/
    I'm still not sure why you are continuing to use the Verilog-A model when it's built in - it will be faster to simulate with the built-in optimised version of the model; the Verilog-A version is normally used as a reference and for initial development, not for real-life usage.
  • yysunj
    yysunj over 5 years ago in reply to Andrew Beckett
    Thank you for your detailed reply!
    yysunj
