  3. What does "Drain diffusion res squares, Source diffusion...
  • Views 4647
What does "Drain diffusion res squares, Source diffusion res squares, estimated operating region, thermal resistance, num of segments, and thermal capacitance" mean in analogLib's ntft?
yysunj
yysunj over 5 years ago
I want to simulate analogLib's ntft at the cadence virtuoso.
By the way, I do not know What does  "Drain diffusion res squares, Source diffusion res squares, estimated operating region, thermal resistance,num of segments and thermal capacitance" mean in analogLib's ntft. (Please refer to Figure 1.)
                                                      Figure 1
Could you tell me What does  "Drain diffusion res squares, Source diffusion res squares, estimated operating region, thermal resistance, num of segments, and thermal capacitance" mean in analogLib's ntft?
Thank you
yysunj
    ShawnLogan over 5 years ago
    Dear yysunj,
    If you examine the graphic you provided, there is a "Help" button. If you click on this button, there is a search field. Entering "ntft" as shown in Figure will provide a link to the symbol for "ntft". Clicking this link shows the result of Figure 2 where I highlight the spectre -h reference for it. The data is also contained in the analogLib reference manual. The terms you mention are all defined and contained in these references.
    The built-in documentation and the On-line Support sites have a tremendous amount of information that can answer most all questions.
    Shawn
    Figure 1
    Figure 2
  • FormerMember
    FormerMember over 5 years ago in reply to ShawnLogan
    Figure 1
    Figure 2
  • yysunj
    yysunj over 5 years ago in reply to FormerMember
    Thank you for your kindly reply.
    I searched reference , but I can not find any information for my question. (Please refer to figure.1)
    In this case, How can I find a answer for my question?
    Please tell me
    Thank you
    yysunj
    Andrew Beckett over 5 years ago in reply to yysunj
    A good place to look is in the same manual I mentioned with regards to bsimbulk - the Spectre Circuit Simulator Components and Device Models Reference at <SPECTREinstDir>/doc/spectremod/spectremod.pdf - it has a chapter on the RPI TFT models, and it shows the equations for the drain and source resistance.
    However, the nrd/nrs parameters are common to many transistor models, and the idea is that there's a sheet resistance (the model parameter rsh) and the actual resistance is determined by the number of squares of the source/drain area multiplied by that sheet resistance (if you look in the model reference you'll see there are other options for modelling this resistance which include other terms, but generally it's the number of squares times the sheet resistance). As with most planar resistances on silicon, it's the number of squares (i.e. length/width) that determines the amount of resistance.
  • yysunj
    yysunj over 5 years ago in reply to Andrew Beckett
    Thank you for your clearly reply!
    yysunj
