  3. Reading IC5033 schematic in IC6.1.6 ?
  • Views 13790
Anon481
Anon481 over 5 years ago
Sorry not sure if this is the correct place for this but here goes. Can you read Cadence virtuoso IC5033 schematic files in IC6.1.6? Need to open some files and they were generated on IC5033. I imported them into my Cadence folder, I can see it in the list of cells but when I click on the schematic it won't open. Any help would be appreciated. Any help would be much appreciated. Thanks.
    You will need to use either the Tools->Conversion Toolbox menu in the CIW to convert CDB to OA (IC5033 used the CDB database format; IC616 uses OpenAccess), or the command line cdb2oa tool to do the conversion…
    You will need to use either the Tools->Conversion Toolbox menu in the CIW to convert CDB to OA (IC5033 used the CDB database format; IC616 uses OpenAccess), or the command line cdb2oa tool to do the conversion.
  • Anon481
    Anon481 over 5 years ago in reply to Andrew Beckett
    So I'm stuck on how to perform the conversion correctly. It's a problem with how I have my libraries organized. I pick the 'home/username/NCSU_FreePDK45'  as the directory and move all the libraries over except the one I want to convert but it gives the error message:
    ERROR (CDBOA-107): You cannot run the translator in the same directory as the
    CDBA cds.lib file. Doing so would add OpenAccess library
    definitions to the CDBA cds.lib file, which is not
    permitted. Run the translator from a different directory.
    But the thing I don't understand is if I pick any other directory it says the cds.lib file specified does not exist or the file is not readable.
    Andrew Beckett over 5 years ago in reply to Anon481
    First of all, I would get the OpenAccess-enabled version of the NCSU PDK from NCSU (rather than trying to convert it yourself). Then start virtuoso in a new directory with the cds.lib just pointing at libraries from the Cadence installation plus the OA-enabled version of NCSU PDK.
    Then you can run the conversion toolbox and point it at the cds.lib from your original IC5033 work area. You can then tell it which libraries to convert.
    Andrew Beckett over 5 years ago in reply to Andrew Beckett
    You could also read the documentation on migrating from CDB to OpenAccess... (which is shipped with IC616; can be found using cdnshelp or the Help menu in Virtuoso).
