  3. Monte carlo simulation error (no process variations were...
  • Views 17771
Monte carlo simulation error (no process variations were specified in the statistics block)
Afshin Amoo
Afshin Amoo over 5 years ago
I'm going to do the Monte carlo simulation on my design, but I get this error:
Attempt to run Monte Carlo analysis with process variations, but no process variations were specified in the statistics block.
Does Anyone know what's the reason and how can I fix it?
BTW, the technology I'm working with is TSMC130n.
Thanks in advance,
Afshin
    Hi Afshin,
    I don't know the specifics for the models you're using - it is probably dependent upon the precise variant of TSMC 130n process and the version of the models/PDK. Usually you have to include a particular model section to get the statistics blocks (so rather than some ff/ss type corner, there's usually a "stat" model section that needs to be included. In essence it needs to load a block with statistics { ... } from one of the model files.
    This is probably covered in the documentation for the PDK - if not, you should contact TSMC as they can best advise you for the specific technology you're using.
  • Afshin Amoo
    Afshin Amoo over 5 years ago in reply to Andrew Beckett
    Thank you so much for your Help.
    Yes, that was the problem and now, by adding those "stat" models, it's working.
