  3. how to append the output data to previous file
  • Views 12663
Yea Chul
Yea Chul over 5 years ago
hi all
i try extracting capacitance using captab
but when i sweep multiply, the output table from captab is not overwrited
and new output data is generated
is there any method to overwrite output data to previous one?
thanks in advance
    It's unclear what you actually want here. The title asks "how to append the output data to previous file". Well, that's what it does right now (at least with SPECTRE19.1 - you didn't mention what version you're using). I get a single file capnode_b which has sections for each sweep point - showing the capacitance tables for each.
    Later you're asking how to overwrite the data. I don't believe this is possible, but I can't see why you'd ever want that since the previous sweeps would be pointless. You can give each a unique name by specifying file="capnode_b_%A" (%A will be replaced by the nested analysis name).
    BTW, the infoname=capinfo on the first sweep is an incorrect parameter for a sweep analysis, and this will be ignored by Spectre.
  • Yea Chul
    Yea Chul over 5 years ago in reply to Andrew Beckett
    it's really helpful thank u so much
