  3. Need to get routing layers info from tech db
  • Views 14651
Utkarsh03
Utkarsh03 over 5 years ago
Hi
I am trying to get the routing layers data from a technology file, I have dumped the tech file and the layerRules section, routingDirection section exists inside that. However, when I am executing the below three lines I am getting "nil" as the output for all three.
tf=techGetTechFile(ddGetObj(techLibName))
techIsPrRoutingLayer(tf "M1")
techGetPrRoutingDirection(tf "M1")
techGetPrRoutingLayers(tf)
Can you please let me know what is the issue here.
Thanks in Advance
Utkarsh
    Hi Utkarsh,
    This article indicates that the techGetPr* functions are for legacy support these days and ideally you should go to the constraintGroups instead: API techGetPrRoutingLayers(tfId) does not work with ITDB
    However, if techGetPrRoutingLayers returns nil, then that means you do not have a LEFDefaulteRouteSpec constraint group, or it doesn't have a validLayers constraint within it. The routing directions information doesn't come from a routingDirections constraint within that constraint group (rather bizarrely) but from the routingDirections specification within the layerRules section (the documentation does say this). The techGetPrRoutingDirection function only retrieves from the routingDirections in layerRules if the LEFDefaultRouteSpec constraint group exists though....
  • Utkarsh03
    Utkarsh03 over 5 years ago in reply to Andrew Beckett
    Thank you Andrew for your answer. I just verified that LEFDefaultRouteSpec does not include any validLayers constraint within it. That is why probably I am getting nil. Can you please suggest other method to extract Routing Layers info from the tech db?
    Utkarsh
    Andrew Beckett over 5 years ago in reply to Utkarsh03
    Well, I'm pretty sure  you're going to need validLayers in whichever constraint group you're using for routing (it may not be LEFDefaultRouteSpec). Say it's called something else, you can do this:
    cg=cstFindConstraintGroupIn(tf "LEFDefaultRouteSpec_gpdk045")
    then:
    cstFindFirstConstraint(cg "validLayers")~>value
    cstFindFirstConstraint(cg "routingDirections" list("Metal3"))~>value
    This is assuming that there's validLayers and routingDirections defined within the constraint group in question.
  • Utkarsh03
    Got that!! In my techfile we have a contraint group called "default" and valid layers is inside that. Thankyou Andrew, above commands work perfect.
