  3. Displaying value in ADE Explorer Outputs without generating...
  • Views 17502
Displaying value in ADE Explorer Outputs without generating a plot
mikewu
mikewu over 5 years ago
Say I create an expression in the Calculator that returns a single value instead of a plot. I send that expression to ADE Outputs. In ADE-L when I hit the plot button or run a new simulation, the expression would be evaluated and the result displayed in the results table. In ADE Explorer, the result is not displayed in the results table unless I also click the "plot" checkbox for that expression, in which case I do get the displayed result (which I want) but I also get a single-point plot on the plotting window (which I absolutely do not want).
Am I missing some setting in ADE Explorer? Or is the behavior changed from the old ADE-L?
    Press this button, and then turn off the Plot Scalar Expressions checkbox: You might need to fiddle with the Plotting option - in some versions the checkboxes are greyed out until you switch from Auto…
    ShawnLogan over 5 years ago
    Dear mikewu,
    In my experience, the behavior you are experiencing is consistent with what I also experience and is the apparent default behavior in Explorer.
    Shawn
    You might need to fiddle with the Plotting option - in some versions the checkboxes are greyed out until you switch from Auto to something else and then back again.
  • mikewu
    mikewu over 5 years ago in reply to Andrew Beckett
    That did it, thanks.
