  3. CAS Incomplete Net problem
  • Views 15552
Senan
Senan over 5 years ago
I am using the CAS from layout GXL. I found it very useful tool to guide my layout routing. But I am facing a problem when I do the layout of two blocks. I took a snap of part of the design where u3 connection from the second layout cell need to be connected to the u3 net of the first layout cell. The CAS always suggest to connect to the exactly on the pin to remove the missing connectivity message, while I managed as you see from the image to connect the two u3 nets on different place and the design passed the LVS.
It looks like CAS in hierarchical design only actively check for pins not for net
Thank you in advance
Regards
  • Alex Soyer
    Alex Soyer over 5 years ago +1
    Hello Senan, Maybe you have done an off pin connection ( connecting from top level to lower level shapes directly and not going through the pin). Could you try to run the connectivity extractor with…
  • Alex Soyer
    Alex Soyer over 5 years ago in reply to Senan +1
    Dear Senan, CAS: Check Against Source is then engine comparing your schematic and your layout and it is going to report any differences (parameters, connectivity on devices pins, etc..). Connectivity…
  • Alex Soyer
    Hello Senan,
    Could you try to run the connectivity extractor with a hierarchy depth of 1?
    Click on menu "Connectivity"> "Extract Layout" then in the new form click "Options" then set the "Extract Connectivity Level" to 1.
    Alex
  • Senan
    Senan over 5 years ago in reply to Alex Soyer
    Dear Alex,
    Thank you for your help
    Your suggestion is perfectly working, I had no idea about the "Extract Layout", its looking helpful tool,
    could you please also refer me to some materials or cadence lectures to read more about it.
    Thank you once again
    Regards
  • Alex Soyer
    Dear Senan,
    Connectivity Extractor: it is going to look at the physical connectivity and propagate the connectivity along the shapes to detect if you have opens or shorts.
    I think this RAK (Rapid Adoption Kit) on the basics of Layout XL should be a good starting point:
    https://support.cadence.com/COSAgreementPage?artId=a1Od00000066Mz6EAE&id=069d0000003H2jLAAS&sq=null
    Alex
  • Senan
    Thank you Alex,
    That is very useful, I am going to cover this nice material
    Have a nice time
    Best Regards
