  3. "ERROR: attempt to access a quantity that depends on the...
  • Replies 13
  • Views 7318
"ERROR: attempt to access a quantity that depends on the time derivative" in Verilog-A
rhanna
rhanna over 5 years ago
I'm new to verilogA and trying to compile a module including the following nested loop in an analog process:
for(k=0; k<5; k=k+1) begin
     for(j=0; j<25; j=j+1) begin
          I(x_node[k])<+ V(x_node[k]) + (1-alpha)* h*ddt(V(x_node[k])) - tanh(mul_Vin_w_Vin + mul_c_w_Vin + w_rec[j]*(V(x_node[k]) - alpha* h*ddt(V(x_node[k]))) + b_node[k]);
          V(Vout)<+ w_Vout[k] * V(x_node[k]) + b_Vout;
     end
end
where:
k, j are genvars.
x_node is a vector of internal nodes.
h, mul_Vin_w_Vin, mul_c_w_Vin, alpha, b_Vout are assumed to be constants.
w_rec, b_node, w_Vout are parameter vectors.
Vout is an output port.
I'm trying to force the current branched from these nodes to 0 and use the simulator to solve for V(x_node[k]).
I had this error at the bolded line:
Error: Encountered an attempt to access a quantity that depends on the time derivative. The software allows only symbolic use of such quantities. Either remove the need to access this quantity or create an internal node, assign the voltage of the internal node to this quantity, and access the voltage of the internal node.
I couldn't fully understand what's the problem with using "ddt()" in the expression, Can you please explain a bit more about the problem and the suggested solution?
Thanks in advance,
Ramy
    Andrew Beckett over 5 years ago in reply to rhanna +1
    Hi Ramy, You're missing a close parenthesis (I've added it back - and highlighted it in red below): I(x_node[k])<+ V(x_node[k]) + (1-alpha)* h*ddt(V(x_node[k])) - tanh(mul_Vin_w_Vin + mul_c_w_Vin …
    Hi Ramy, The issue is because of the assignment to the variable c earlier in the analog block - that's then used in the calculation of mul_c_w_in in step 2, and then that's used within the tanh() in…
    Hi Ramy,
    In general you should not need to try to control the timestep within a Verilog-A model - the simulator will do that automatically to ensure the specified simulator accuracy tolerances are met. However, it's possible that you're trying to model some kind of discrete sampled-data system (I've not even tried to spend time looking at the details of what you're actually modelling), but if so you might need to set up some kind of timer/clocking scheme to ensure that this sampled-data behaviour is operating.
    The point I had made about scaling the values appropriately is that by using a contribution operator (<+) to contribute the derivative to an internal node (which is marked as electrical), you're then creating an equation that needs to be solved as if it were a voltage (if using V(); it would be a current if you used I()). Given that a Verilog A discipline has two quantities (electrical has the Voltage and Current quantities), and each quantity has controls on the absolute value used in the tolerance criteria used in many places in the numerical algorithms - all of the form:
    delta < reltol*value+abstol
    The abstol is set differently for each quantity, and is usually set to a millionth of a typical signal value (so vabstol is 1uV, and iabstol is 1pA by default). What this means is that you want the values on these internal nodes to be at similar "voltage" levels to other signals in the circuit - i.e. of the order of 1V.
    So I was suggesting you scale the value as part of the contribution statement, given that you can then unscale it when it's used in a subsequent equation. This will keep the algorithms happier, and less likely to introduce errors.
    However, that may not be the root cause of your convergence difficulties - you might be advised to contact customer support so that somebody can look at your real example with coefficients and circuit and analysis setup rather than just the model (or simplified versions of the model). Even if you were to post that all here, I don't realistically have the time to check it and respond (I answer here in my spare time as it's not part of my role at Cadence).
    Anyway, hope that helps!
  • rhanna
    rhanna over 5 years ago in reply to Andrew Beckett
    Thanks a lot for the detailed explanation.
    So scaling a value could be as an example: V(c)<+ scaling_factor * ddt(V(in)); //c is an internal node
    So that any update (delta) should meet the criterion you mentioned above and V(c) converge in the end to a value in the allowed range.
    Then wherever V(c) is used, it should be in the form: (1/scaling_factor) * V(c)
    Did I get your point correctly?
    Ramy
    Yes, you got my point correctly.
