  3. Canceling out the parasitic diode in Layout
  • Views 12822
Hossein Eslahi
Hossein Eslahi over 5 years ago
Dear All,
I have designed a circuit in 22nm FDSOI technology which can offer frequency modulation if a bias is applied on the back-gate of a NMOS (HVTNFET model). In this layout, consequently, I should use deep NWELL to separate global substrate and local substrate of that particular transistor with body bias. Following this approach, I should draw an NWELL ring around this Tr and connect it to Vdd otherwise the parasitic diode between local pwell and deep NWELL cause the total power consumption to increase incredibly.
My question is how I can have access to the nwell ring in schematic view? I have created an NPLUS contact on top of nwell ring and introduce a pin for it but I do not know how I should introduce such a pin in the schematic. In addition, although there is an extra pin in layout compared to the schematic, LVS cannot realize this pin and is always clean.
I appreciate any assistance in this regard.
Cheers,
Hossein
