  3. Adding wreal input and output bus in verilog-AMS
  • Views 17835
RFStuff
RFStuff over 5 years ago
Dear All,
I need to add wreal input and output bus to a model code written already in VerilogAMS.
I tried to add wreal input/output port like "output wreal [4:0] data_out". But this gives error during compilation.
Is there anyways I can achieve the above ?
Kind Regards,
    See VerilogAMS wreal vectors and arrays . You can use this instead:
    output wreal data_out[4:0];
    Whilst I found a few discussions about it, I haven't seen any plans to add support to the "before" approach that is in the Verilog AMS LRM. However, practically the "after" approach works...
  • RFStuff
    RFStuff over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks a lot. Could you please little bit more clear about before approach and approach you have talked about.
    Kind Regards,
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to RFStuff
    Did you read the information at the link that Andrew mentioned? I find that pretty clear and detailed.
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann
    Thanks Frank. Indeed the "before" and "after" terms are simply referring to things mentioned in the linked article.
  • RFStuff
    Thanks Andrew and Frank.
    I went through the doc. and  the terms are clearly explained.
