  3. Verilog-A white_noise function returns 0 in transient noise...
  • Views 14807
Verilog-A white_noise function returns 0 in transient noise simulation
threepwood06
threepwood06 over 5 years ago
Hi everyone,
How come the white_noise function returns 0 in transient noise simulation?
As a matter of fact, for a reason I ignore, depending on the whether outside probably, sometimes it works, sometimes it doesn't... Rearranging my verilog-A code, changing the variables names, could turn on or off the white_noise function. Any idea?
I use Maestro with AMS Mulithreading.
Thanks a lot in advance.
FYI my ongoing 8-buffers ring VCO verilog-A code, including jitter noise generated by white_noise function:
`include "constants.vams"
`include "disciplines.vams"
module cdr_model_vco_8phases(ckn_out, ckp_out, measperiod_out, test, vctrl, vdd);
output [0:7] ckn_out;
electrical [0:7] ckn_out;
output [0:7] ckp_out;
electrical [0:7] ckp_out;
output measperiod_out;
electrical measperiod_out;
output test;
electrical test;
input vctrl;
electrical vctrl;
input vdd;
electrical vdd;
parameter real pKVDD = 0 ;
parameter real pKVCO = 8e+09 ;
parameter real pFVCO0 = 4e+09 ;
genvar index;
real Ji[0:7];
integer ck_int[0:7];
real freq, del;
real tevent;
analog begin
@( initial_step ) begin
for( index=0; index<=7; index=index+1 ) begin
ck_int[index] = 0;
end
freq = pFVCO0 + pKVCO*V(vctrl) + pKVDD*V(vdd);
if( freq<1e9 ) freq=1e9; // VCO frequency clamp
del = 1.0/(16.0*freq); // unit buffer delay
tevent = $abstime + del;
index = 0;
end
Ji[index] = white_noise( ( (2p/3)**2 )/2G );
end
@( timer(tevent) ) begin
ck_int[index] = 1-ck_int[index];
del = 1.0/(16.0*freq) + Ji[index]; // unit buffer delay
if( index==7 ) index=0; else index=index+1;
end
V(ckp_out[index]) <+ transition( ck_int[index] , 0 , 10f );
V(ckn_out[index]) <+ 1-V(ckp_out[index]);
end
//V(test) <+ Ji[0];
end
endmodule
  • threepwood06
    threepwood06 over 5 years ago +1
    I've found a workaround. Actually the white_noise must be injected into an ELECTRICAL instead of a real, and then this Electrical injected into a real to be exploitable in the calculations: electr…
    I'd suggest for this (and your other question) that you contact customer support. Others here may be able to help of course, but I have no bandwidth this week to experiment and investigate (the day job is keeping me busy!)
  • monglebest
    monglebest over 5 years ago
    It shouldn't work. verilog-A noise is small signal noise, your transient is large signal analysis, I thought my expectation is ZERO always. I only get it work in "noise" analysis. Not fully understood the mechanism
    Andrew Beckett over 5 years ago in reply to monglebest
    However, the small-signal noise contributions will have an effect during transient noise simulations, in a similar fashion to the noise contributions in primitive devices. They get translated into a time-domain source instead. As I said, I don't have the time this week to investigate the issue so hopefully the original poster contacted support as I suggested.
  • threepwood06
    electrical electricalvariable;
    real realvariable;
    real miscvariable;
    analog begin
    V(electricalvariable) <+ white_noise( stuff );
    realvariable= V(electricalvariable);
    miscvariable = misc calculation with realvariable...;
    V(test) <+ V(miscvariable);
    end
    This is a bit cumbersome and I think this is a bug from Cadence. Hope this will be fixed in future realeases.
    Just for information, the VA noise build-in functions do work in transient noise simulations, not only in small-signal analysis, contrary to what the Cadence support has told to me; I've been using VA noise functions for years this way so far.
    Regards.
