  3. HISIM-HV models
  • Views 13425
HISIM-HV models
pejmank
pejmank over 5 years ago
Trying Simulation HISIM-HV 2.40; in virtuoso ADE-L environment, it does not seem to read the level =73 or 75 model number.  Two questions
1) what is the appropriate level number
2) where do I get this information; have been digging through all document under Cadence support related to Hisim-HV and not mention level number
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago
    Spectre does not use a level number to specify the model type. You can find the model syntax and a sample model statement at support.cadence.com/.../techpubDocViewerPage
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann
    Actually, spectre does support SPICE syntax model files that use common level numbers. From "spectre -h hisim_hv" you can see that level=73 is the level number. This netlist does run (it's a stupid example which doesn't do anything):
    simulator lang=spice
    .model nch nmos level=73
    simulator lang=spectre
    VD (d 0) vsource dc=2
    VG (g 0) vsource dc=2
    M1 (d g 0 0) nch w=10u l=10u
    dc dc
    The log file tells you it's using hisim_hv.
    Frank is right though for spectre syntax models - these don't use level numbers - the model above would be as follows if defined in spectre syntax:
    model nch hisim_hv type=n
    ADE doesn't need to know anything about model level numbers - that's the simulator's problem...
