  3. Layout offgrid problem
  • Views 20541
Senan
Senan over 5 years ago
In the middle of my layout design I started to receive a new error of "OFFGRID". I have read some advices from net about changing the minor and major spaces from Option > Display, however it is not working.
If I go to the former layout cells which has no DRC problem, by just inserting a new layout element and then It will as well start to complain about the OFFGRID.
Here is the DRC I have
    First of all, the grid spacing is not controlled by the minor and major spaces - that's just for the visual grid (i.e. the dots/lines shown on the display). The snap spacing is what controls the snap grid…
  • Tamsay
    Tamsay over 5 years ago in reply to Senan +1
    A good way to solve such issues is to go for a somewhat bigger, but round number for the snap spacing, go for 0.1u for example, not 0.037u (just examples). Then your new placements should be fine. As…
    First of all, the grid spacing is not controlled by the minor and major spaces - that's just for the visual grid (i.e. the dots/lines shown on the display). The snap spacing is what controls the snap grid - that's probably what's wrong. Without knowing what the allowed grid is for your technology, I can't tell you what to change it to...
  • Senan
    Senan over 5 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you for your reply
    You are absolutely right, it is about the snap spacing as also recently read.
    I kept this value as default as it was since the start of my layout work and was no problem for several cells I have finished, I don't understand why Cadence suddenly recognized that I must change it to fit the used technology.
    I tried to find some notes about the grid setting from the technology files but there was nothing about it, hence I think I will contact the foundry support.
    Generally, I am using the 0.35 µm CMOS technology from XFAB
    Regards
  • Tamsay
    As for the already placed devices, try to round their coordinates with the same logic. This way they snap back the grid.
  • Senan
    Senan over 5 years ago in reply to Tamsay
    I found the information from the foundry of my technology. it is 0.25 µm or recommended 0.5 µm. and this fixed my issue
