  3. Update W/L number in instance property, but resistor "r...
  • Views 3319
Update W/L number in instance property, but resistor "r "value isn't change accordingly
ringamp
ringamp over 5 years ago
Hi everyone
I am just using the PDK from the foundry.  I just followed its cdslib userguide. when I launch the virtuoso IC618 and create schematic. I add one instance of resistor using "add instance". in the "add instance" interface, I can adjust "W","L" value and the "Resistance" parameter (in gray) changed accordingly.
But after I finished the placement of this resistor instance on the schematic, I clicked on its symbol and  pressed "Q". "Instance Property Editor" pop-up. It showed quite native interface: every parameter can be change (no gray area and "W" "L" shows in different places ).it was different from that of "add instance".  I changed "W" "L" and click "apply", the “W” “L” value changed displayed by symbol but the resistance value was the seem value. But CIW window give a warning "*WARNING* CDF parameter "r" reset to "6.0969K""
What I want is the resistance value display by the symbol also change after I modified "W" "L", and the "Instance Property Editor"  interface is in consistent with that of "add instance"
    This sounds as if you have a rather strange set of bindkeys. The normal bind key for "q" would be schHiObjectProperty() whereas it sounds (from your description) that it is invoking the old (very low level) geQuerySelSet() function which doesn't really deal with CDF information which controls the edibility/readability and callbacks for interacting with various components.
    I suggest you take a look at Options->Bindkeys and for the Schematic application search for "q" in the search box at the top, and see what the bindkeys are set to. If it's geQuerySelSet() you might want to find out why it's been changed in your environment, because that is rather non-standard.
    You can probably just enter:
    load(prependInstallPath("samples/local/schBindKeys.il"))
    in the CIW to change back to a more standard default set.
    You didn't give any clue as to which foundry PDK you were using, so this is of course guesswork on my part...
  • ringamp
    ringamp over 5 years ago in reply to Andrew Beckett
    Thanks Andrew, it is Global Foundry/IBM PDK(maybe it is not so welcome on its environment setting) . since there's limited number of foundry, I realize that this information is quite important. I check .il files provided by the foundry (both gfPdkBindkeys.il and gfPdkBindkeysCDS.il), they show the difference on <Key>q exactly as you mentioned. I changed to load gfPdkBindkeysCDS.il in .cdsinit, it is back to normal. Thanks again!
