  3. ADE Explorer - Spec Pass/Fail
  • Views 2876
life
life over 5 years ago
Is it possible to put the 'temperature' variable that exists inside the Corners as a variable inside the "Spec" column during output setups?  For example, I want to normalize my outputs with respect to temperature, and since I am sweeping across multiple temperatures I cannot put a fixed constant.
I tried putting 'temperature' inside the spec equation but when I run it just says "error" under pass/fail column output..
please advise.
thank you
  • life
    I think I figured it out.
    You can go to Results browser, look for design variables temperature, and then send that to calculator to view the equation needed. Then I plugged this into my equation and it seems to be working.
