  3. Need a solution to build pre-computed look-up table man...
  • Views 12881
Need a solution to build pre-computed look-up table manually
circuit apprentice
circuit apprentice over 5 years ago
Hello.
Recently, I read 'Systematic Design of Analog CMOS Circuits', which describes how to apply pre-computed look-up table.
Look-up table is 4-D DCOp table e.g. ID(L, VGS, VDS, VSB) gm(L, VGS, VDS, VSB)...
The book provided look-up table generation tool, and that requires Spectre MATLAB toolbox.
Because I access Cadence through Unix server, and I cannot use MATLAB on the server, I cannot apply that method, so I decided to make look-up table manually.
The method I chose is that...
1. Turn on ADE-L, and run multiple DC parametric analyses at once.
2. Export them as .csv
3. Organize them manually.
(I am a cadence beginner...)
There are many problems I encounter, but the main is that...
Parametric Analyses suddenly comet to a halt without error.
No error message. No freezing. Just halt(pause and continue does not work).
I use multiple duplicated schematics to separate directories.
The fundamental problem which cannot be fixed is that I cannot run MATLAB on the server.
So, I should run simulations and export the results.
1. Is there any solution to fix random halt?
2. Is there a better solution for me?
Thank you!
    Not sure what issue you're facing really, plus you didn't mention which version of the tools you are using. I'd suggest you use ADE Explorer/Assembler which have capacity (especially in the latest IC6.1.8/ICADVM20.1 versions) using LSCS for a very large number of sweep points. They also have an interface to MATLAB, and from my understanding of MATLAB licensing, there's no platform restriction - you just need to install it.
    I'm not aware of any "random halt" even with the obsolete ADE L tool.
  • circuit apprentice
    circuit apprentice over 5 years ago in reply to Andrew Beckett
    Thank you for your replying!
    I decided to use MATLAB, and now I think it is a better decision!
    It's great.
    Sangwon.
