  3. check and save schematic, there's a warning I don't know...
  • Views 7922
check and save schematic, there's a warning I don't know where it comes
ringamp
ringamp over 5 years ago
I copy a schematic from old library (read-only) to new library so that I can edit. After I just copied, and no modification just check and save,
this warning shows:
INFO (SCH-1170): Extracting "XG_CLKBUF_X4" schematic"
Warning: Ignored port name and port order checks because modelName property value "H9SOIFEM_OD25_BFX4" did not match with the cell name "XG_CLKBUF_X4" in view 'symbol' of library 'M4564'.
I don't know where the  "H9SOIFEM_OD25_BFX4"  in symbol view
BTW it's GF PDK
need help!
    If you open the XG_CLKBUF_X4 symbol, and then do Edit->Properties->CellView, then I'm expecting you'll see that there is a modelName property with the value H9SOIFEM_OD25_BFX4. I don't know why that's…
    If you open the XG_CLKBUF_X4 symbol, and then do Edit->Properties->CellView, then I'm expecting you'll see that there is a modelName property with the value H9SOIFEM_OD25_BFX4. I don't know why that's there, but if you delete the property, the warning would go away when you do the check-and-save on the schematic (it's flagged in the cross-view check).
  • ringamp
    ringamp over 5 years ago in reply to Andrew Beckett
    Thanks Andrew~ It is exactly as you expected and the warning goes away.
  • ringamp
    I think someone re-create the logic cell schematic but just re-use an old symbol of the similar cell with different name. so comes the mismatch.
