  3. The Best Router Tables to work with with your Workshop
  • Subscribers 124
  • Views 866
Jhon Mash
Jhon Mash over 4 years ago
Moderator: Removed content of this post as it was edited after initial posting and replaced with spam
    This appears to be due to you having increased the font size. Many older forms don't handle that well (because they are coordinate-based and don't use the newer hi "Layouts" capability; there's a significant infrastructure change needed in ADE to accommodate that, which is why it hasn't happened yet).
    However, you should be able to use the env var as outlined in this article: How to set a large font size in Virtuoso environment for high-resolution monitor displays and be able to scale the forms as per the font size
    This is also covered in this previous post (you may need to click on "next" to see the full thread discussion). I don't know which sub-version of the tools you are using, but I pointed out that you might need to use a more recent sub-version than the one discussed in that thread to deal with some issues that occurred even when using the environment variable to handle the scaled fonts.
