  3. Generating real random number in AMS
  • Views 14087
RFStuff
RFStuff over 5 years ago
Dear All,
Is there any way we can generate real random number with a given mean and sigma  in AMS (without any any analog block) ?
Kind Regards,
    You could use the $dist_normal function (which is standard Verilog) and produces an integer random number with the given mean and standard deviation, and then scale the result. For example:
    module forum7;
    real rnd1;
    integer seed;
    parameter real dmean=1.0;
    parameter real dstddev=0.1;
    parameter integer dscale=1000;
    initial begin
        seed=1;
        #2000 $finish;
      end
    always #50 begin
        rnd1=($dist_normal(seed,dmean*dscale,dstddev*dscale)+0.0)/dscale;
        $strobe("dist_normal:",rnd1);
      end
    endmodule
  • RFStuff
    RFStuff over 5 years ago in reply to Andrew Beckett
    Dear Andrerw,
    Thanks  a lot.
    Kind Regards,
