  3. How to combine two procedure syntax and use by bindkey layer...
  • Views 13094
How to combine two procedure syntax and use by bindkey layer?
toyakoyosu
toyakoyosu over 5 years ago
Hi! All:
I have question about syntax use,
And thru the toggle Bindkey combine two procedure syntax implement  I wanna to
I think toggle keyboard "1" is setMetal1LayerVisible(), and toggle keyboard "Alt +2" is setMetal2LayerVisible()
and maybe toggle keyboard "1" + "Alt+3" can see layer ME1, CONT, M1_CAD_TEXT, ME3, VIA2, M3_CAD_TEXT
how could I set this bindkey combo?
Thanks!!
Virtuoso version is IC6.1.8-64b.500.16
I write the bindkey as below
hiSetBindkey("Layout" "Alt<Key3" "setMetal3LayerVisible()" hiredraw()")
hiSetBindkey("Layout" "<Key>1" "setMetal1LayerVisible()" hiredraw()")
procedure( setMetal1LayersVisible()
leSetEntryLayer('("M1" "drawing"))
foreach( laylsw list(
'("ME1" "drawing")
'("CONT" "drawing")
'("M1_CAD" "TEXT")
leSetLayerVisible (laylsw t)
leSetLayerSelectable(laysw t)
); end foreach
); end procedure
hiSetBindkey("Layout" "<Key>2" "setMetal2LayerVisible()" hiredraw()")
procedure( setMetal2LayersVisible()
leSetEntryLayer('("M2" "drawing"))
'("ME2" "drawing")
'("VIA1" "drawing")
'("M2_CAD" "TEXT")
); end foreach
); end procedure
hiSetBindkey("Layout" "<Key>3" "setMetal3LayerVisible()" hiredraw()")
procedure( setMetal3LayersVisible()
leSetEntryLayer('("M3" "drawing"))
'("ME3" "drawing")
'("VIA2" "drawing")
'("M3_CAD" "TEXT")
); end foreach
); end procedure
    I really don't understand your question (your English is very unclear - I understand that's probably not your first language, but I just don't understand what you're asking). I certainly can see that…
    I certainly can see that your bindkey definitions are all incorrect though, because they have:
    1. An extra quotation mark in the final argument
    2. A call to an incorrectly spelled function - it should be hiRedraw() not hiredraw()
    So they should be something like:
    hiSetBindkey("Layout" "Alt<Key3" "setMetal3LayerVisible() hiRedraw()")
    However, I don't understand what you're talking about "toggle Bindkey" or "toggle keyboard". I'm not sure what is "toggling" here, or what you're trying to combine. Please clarify!
    Kind Regards,
  • toyakoyosu
    toyakoyosu over 5 years ago in reply to Andrew Beckett
    Hi! Andrew, sorry make you inconvenience,
    this is not my first language, my mother tongue is Taiwanese,
    I try to make procedure as below,
    and hopefully you know I talk about,
    1. Type Keyboard "3" show "via2", "Metal3", "ME3_CAD" layer, type Keyboard "2" show "via1", "Metal2" and "ME2_CAD" layer
    2. Type Keyboard "2" and "alt+3" show "via1", "Metal2","ME2_CAD", add "Metal3", "via2", "ME3_CAD" layer
    3. Type keyboard "alt+3" again, remove  "Metal3", "via2" layer,
    Andrew Beckett over 5 years ago in reply to toyakoyosu
    I still don't quite get what you're asking. Are you asking that when you press (say) 3, it always sets layers associated with metal3 to be visible, but when you press (say) alt+3 it toggles the visibility of the metal3-related layers (so if they are invisible, they become visible; if they are visible, they become invisible)? Then the same for 1 (and alt+1) - metal1-related layers, and 2 (and alt+2) - metal2-related layers?
    Your sequence didn't quite make sense to me if that's what you wanted - as I would have expected that pressing alt+3 in the second step above would have removed "Metal3", "via2", "ME3_CAD" (since they were already visible after pressing 3 in step 1), and also in step 3 you didn't mention "ME3_CAD" being removed. So it's hard for me to see precisely what you want...
