  3. Stop an area of a schematic being netlisted.
  • Subscribers 130
  • Views 12226
FAwqati
FAwqati over 4 years ago
It would be extremely useful when debugging simulations to quick stop parts of a schematic being netlisted.
Im thinking some kind of layer or bounding box.
Current workaround = is saving hacked versions of schematics which is not ideal.
Thanks in advance for your answers.
Faisal
    Hi Faisal,
    Area select the instances you want omitted, and then hit shift-DEL (the key binding shows up on the Right Mouse menu over an instance, provided that you don't have multiple things selected).It's also Edit->Ignore Instanes in the pulldown menus. This toggles the status - if they are being ignored, then they become netlisted again. When ignored there's a big fat red cross through each instance.
    If using the hierarchy editor, you can also select the instances in the hierarchy editor tree (or via cross-selection from the schematic) and use bind to open. This avoids editing the schematic, although it's not clearly visualised on the schematic.
  • FAwqati
    FAwqati over 4 years ago in reply to Andrew Beckett
    Worked an absolute treat :) thank you !
    Ps. If only you got a penny for every quick fire fix you reply ....
  • Frank Wiedmann
    Frank Wiedmann over 4 years ago in reply to Andrew Beckett
    As an additional service, here is the corresponding section of the manual: support.cadence.com/.../techpubDocViewerPage
  • FAwqati
    FAwqati over 4 years ago in reply to Frank Wiedmann
    Thanks Frank ! Much appreciated.
