  3. No such feature exists. error from lmutil lmdiag comman...
  • Views 15027
No such feature exists. error from lmutil lmdiag command
Layne Bunker
Layne Bunker over 5 years ago
Some of the 111 license file entries are giving me "No such feature exists." when I run lmutil lmdiag command.  Some of the 111 licenses are fine.  All the license entries are from the same license file (shown below). This problem started to happen after updating to new lmgrd version.
Error from lmutil lmdiag command (redacted to remove license info) :
"111" v6.18, vendor: cdslmd, expiry: 30-apr-2021
vendor_string: UHD:PERM
License server: keyserver.XXXXXXX
floating license starts: 16-apr-2021, expires: 30-apr-2021
Requests from the same USER/HOST/DISPLAY do not consume a new license
This license can be checked out
Enter <CR> to continue:
"111" v6.18, vendor: cdslmd, expiry: 30-jul-2021
floating license starts: 16-apr-2021, expires: 30-jul-2021
This license cannot be checked out because:
Feature: 111
License path: /server/cad/cadence/license/license.txt:
FlexNet Licensing error:-5,147
License File entries.   (redacted to remove license info)
FEATURE 111 cdslmd 6.18 30-apr-2021 2 XXXXXX \
VENDOR_STRING=UHD:PERM DUP_GROUP=UHD vendor_info=16-apr-2021 \
ISSUER=XXXXXXX
FEATURE 111 cdslmd 6.18 30-jul-2021 10 XXXXXXF \
ISSUER=XXXXXXXX
FEATURE 111 cdslmd 6.18 30-jun-2021 2 XXXXXXXX \
ISSUER=XXXXXXX
    If you've updated to the latest "Lic+Config_Utils" release on downloads.cadence.com (i.e. the latest lmgrd and cdslmd versions) and this is happening, you should contact customer support.
    There is a requirement that with the most recent software versions (and this is across the board with Cadence tools as they gradually adopt the new licensing kits) that you are on the latest sub-versions of the licensing software.
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Andrew Beckett
    Details about this can be found at downloads.cadence.com/.../Documents.eo
