  3. How to move symbol origin for only SOME instances
  • Views 14271
Ahmed A Elsayed
Ahmed A Elsayed over 5 years ago
About symbol origins in cadence virtuoso,
I have an old symbol with a messed up origin. It is inconvenient when placing a new instance. However, many schematics use the symbol so if I change the origin using Edit->Origin it will break all existing schematics which use the device. Is there a way to  fix the symbol position (to counteract or offset the change) in a schematic hierarchy such that existing schematics don't break?
sub-version  IC6.1.8-64b.500.14
    I don't think this is possible right now - although it did get me thinking about a way we might be able to enhance the tool to allow such a possibility in future. For now you could create a copy of the…
    For now you could create a copy of the symbol (e.g. called "symbolNew") and move the origin on that symbolNew view. Then create new instances using symbolNew rather than symbol...
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Andrew Beckett
    By the way, an example for such a symbol with an "interesting" origin is the ideal_balun from analogLib.
  • Ahmed A Elsayed
    Ahmed A Elsayed over 5 years ago in reply to Andrew Beckett
    Thanks Andrew.
