  3. importing spice model into cadence virtuoso ic design
  • Replies 7
  • Views 19242
Hazem Al Indari
Hazem Al Indari over 5 years ago
I need to use adg1436 spice model in my simulation, I tried to add a new cell with cell view of type spice, but I get tens of parsing errors when I try to save it.
Can you please explain for me how can I use spice models in Virtuoso?
This is the spice model am using: https://www.analog.com/en/license/spice-models?mediaPath=media/en/simulation-models/spice-models/ADG1436.cir&modelType=spice-models
and here is the parsing error am getting:
Warning from parser in `ADG1436'.
".../breakoutboard/adg1436/spiceText/spice.spc", line 78: Warning: Illegal scale factor suffix `h' in numerical literal `11h'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 79: Warning: Illegal scale factor suffix `l' in numerical literal `11l'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 80: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 80: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 82: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 82: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 106: Warning: Illegal scale factor suffix `b' in numerical literal `111b'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 108: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 108: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 109: Warning: Illegal scale factor suffix `c' in numerical literal `111c'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 110: Warning: Found an unquoted ambiguous expression that contains the `*' character. Therefore, the part of the expression after `-14--0.528753713125263' will be treated as a comment.
".../breakoutboard/adg1436/spiceText/spice.spc", line 110: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 110: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 112: Warning: Illegal scale factor suffix `d' in numerical literal `111d'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 122: Warning: Illegal scale factor suffix `i' in numerical literal `11i'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 122: Warning: Illegal scale factor suffix `j' in numerical literal `11j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 123: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 124: Warning: Illegal scale factor suffix `j' in numerical literal `11j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 149: Warning: Illegal scale factor suffix `b' in numerical literal `211b'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 151: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 151: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 152: Warning: Illegal scale factor suffix `c' in numerical literal `211c'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 153: Warning: Found an unquoted ambiguous expression that contains the `*' character. Therefore, the part of the expression after `-14--0.528753713125263' will be treated as a comment.
".../breakoutboard/adg1436/spiceText/spice.spc", line 153: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 153: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 155: Warning: Illegal scale factor suffix `d' in numerical literal `211d'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 165: Warning: Illegal scale factor suffix `i' in numerical literal `21i'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 165: Warning: Illegal scale factor suffix `j' in numerical literal `21j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 167: Warning: Illegal scale factor suffix `j' in numerical literal `21j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 177: Warning: Illegal scale factor suffix `h' in numerical literal `12h'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 178: Warning: Illegal scale factor suffix `l' in numerical literal `12l'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 179: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 179: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 181: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 181: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 205: Warning: Illegal scale factor suffix `b' in numerical literal `121b'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 207: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 207: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 208: Warning: Illegal scale factor suffix `c' in numerical literal `121c'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 209: Warning: Found an unquoted ambiguous expression that contains the `*' character. Therefore, the part of the expression after `-14--0.528753713125263' will be treated as a comment.
".../breakoutboard/adg1436/spiceText/spice.spc", line 209: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 209: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 211: Warning: Illegal scale factor suffix `d' in numerical literal `121d'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 221: Warning: Illegal scale factor suffix `i' in numerical literal `12i'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 221: Warning: Illegal scale factor suffix `j' in numerical literal `12j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 222: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 223: Warning: Illegal scale factor suffix `j' in numerical literal `12j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 248: Warning: Illegal scale factor suffix `b' in numerical literal `221b'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 250: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 250: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 251: Warning: Illegal scale factor suffix `c' in numerical literal `221c'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 252: Warning: Found an unquoted ambiguous expression that contains the `*' character. Therefore, the part of the expression after `-14--0.528753713125263' will be treated as a comment.
".../breakoutboard/adg1436/spiceText/spice.spc", line 252: Warning: Parameter `>', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 252: Warning: Parameter `<', specified for primitive `bsource', has been ignored because it is an invalid instance parameter. Specify a valid instance parameter and rerun the simulation. Type `parser -h bsource' to get more information on valid instance parameters.
".../breakoutboard/adg1436/spiceText/spice.spc", line 254: Warning: Illegal scale factor suffix `d' in numerical literal `221d'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 264: Warning: Illegal scale factor suffix `i' in numerical literal `22i'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 264: Warning: Illegal scale factor suffix `j' in numerical literal `22j'.  Ignored.
".../breakoutboard/adg1436/spiceText/spice.spc", line 266: Warning: Illegal scale factor suffix `j' in numerical literal `22j'.  Ignored.
    ShawnLogan over 5 years ago in reply to FormerMember +1
    Dear Hazem Al Indar, I apologize, but my incomplete reply was posted when I logged into the forum.. In addition, SPICE syntax only supports capital letters and the node names you specify in lines 78…
    Andrew Beckett over 5 years ago in reply to ShawnLogan +1
    I think the main issue is that this model looks more like PSPICE than Berkeley SPICE. Shawn's not quite correct about SPICE only supporting capital letters (that's not true - it's case insensitive). However…
  • Frank Wiedmann
    Frank Wiedmann over 5 years ago in reply to Andrew Beckett +1
    I would guess that the model is intended for Analog's LTspice, which says in its manual: "Nodes names may be arbitrary character strings."
  • FormerMember
    FormerMember over 5 years ago
    I looked through your post and did not find an error statement. There are multiple warnings that I believe you need to address, but there was no error. Did I overlook the error? It appears there are several syntax issues in your SPICE file as the statements are not consistent with SPICE. I think you will need to modify these lines. For example, referring to your first set of warnings regarding lines 78 - 80,
    the syntax provided in the file listing is:
    * VOLTAGE SUPPLY REQUIREMENT
    S116 11h 3 11k 6 VON
    S117 11l 11k 11l 6 VON
    Ech119 11l 6 VALUE = { IF((V(5)<=-0.5 & V(5)>=-16.5) & (V(13)<=16.5 & V(13)>=4.5), 5 , 0.01 ) }
    However, the "S" component is not a valid SPICE independent source name.
    In addition, SPICE syntax only supports capital letters and the node names you specify in lines 78 and 79 and 80 contain lowercase letters "h" and "l".
    I would suggest you consider editing the file and making its syntax SPICE compatible. A quick reference to the syntax of a SPICE file is at URL:
    https://web.stanford.edu/class/ee133/handouts/general/spice_ref.pdf
    Hence, examine each warning and address the warning by modifying the line(s) referred in the warning. Although these are not errors, my concern is that the response of the circuit represented by the SPICE file will not be what it is intended to provide.
    Does this help at all?
    Shawn
    I think the main issue is that this model looks more like PSPICE than Berkeley SPICE. Shawn's not quite correct about SPICE only supporting capital letters (that's not true - it's case insensitive). However, normally SPICE would either have numerical node names, or alphanumeric - but in that case they can't start with a number.
    Anyway, if you create the view as a pspice view, you get far fewer problems (only 4) and those are easily fixed by substituting 11j for j11 (for example) throughout the file. That said, it's a bit odd why it complains just about 11j and not about all the other suffixed nodes in the netlist (I think this would be worth raising with customer support).
    It's unclear to me what dialect of SPICE the models are intended for - I couldn't see that on the ADI site.
  • Frank Wiedmann
    Andrew Beckett over 5 years ago in reply to Frank Wiedmann
    Frank,
    That's quite likely, I agree. I also found that if you actually try to simulate with this model (using the pspice_include), then further errors occur, so it would definitely need the original poster to follow up with customer support to address any support needs. First it would be best for the original poster to find out what dialect it really is intended for.
  • Hazem Al Indari
    Hazem Al Indari over 5 years ago in reply to Frank Wiedmann
    Exactly right, my model is intended to be used in LTspice but we are moving our workflow completely to cadence tools.
    Thank you very much all for the help.
    Andrew Beckett over 5 years ago in reply to Hazem Al Indari
    I did check to see whether there had been specific requests for Spectre to support LTSPICE models - I didn't find anything specific so far. There is an article which talks a little about PSPICE support for LTSPICE models, but that's really about the PSPICE simulator itself.
    So as I often suggest, I think you should contact customer support - and framed by your specific needs, would be worth discussing the possibility of LTSPICE model support within Spectre. Of course, it would need to be guided by demand for this in terms of prioritisation.
