  3. Print high-resolution layout image in cadence virtuoso
  • Views 17082
srour
srour over 5 years ago
Hello gentlemen,
I apologize for the inconvenience or inappropriate writing, because it is my first time to writein the community,
I work on a project and I want to get high resolution image from the layout so I have printed it instead of export png  by .cdsplotinit file with extension .ps or .ps then I convert it to pdf from any website,the problem that the pdf shows the layout duplicated two layouts over each other i have tried this on the schematic and no problem has occured
.cdsplotinit file is
I'm using IC6.1.7-64b.78
.cdsplotinit code file
I have converted the file from .ps to .pdf by using this website
  cloudconvert
.ps and .pdf files
    First of all, the forum guidelines (that I mentioned elsewhere) specifically ask you not to use proprietary formats like "rar". This is not universally available - better to use standard utilities (usually…
    First of all, the forum guidelines (that I mentioned elsewhere) specifically ask you not to use proprietary formats like "rar". This is not universally available - better to use standard utilities (usually shipped with the OS) such as tar, zip, gzip, bzip2.
    I didn't know which of the many printers in your .cdsplotinit you were using - I picked PDF_3000dpi and the resulting PostScript was fine. I was using the same version of the tools you were.
    I can see your PostScript has these overlapping shapes - however, I don't know whether that's just because the layout itself is wrong - not everything is overlapped.
    So, I'd suggest:
    1. You check with a newer version - you're using the base release (no hotfixes) of IC6.1.7 and your release is 5.5 years old. I didn't find any reports of the issue you're seeing, but the first thing you should check whether you can reproduce in a newer version.
    2. Check the layout itself - is there something wrong with that?
    3. If the problem is still reproducible with the latest versions, contact customer support (with the info on which of the .cdsplotinit printers you used).
  • srour
    srour over 5 years ago in reply to Andrew Beckett
    First, thank you for your time
    second, I found that it prints two layouts one is the cell view and the second is the zoomed view I see in front of me so I zoomed it out and  solve the problem until i update my version of tools
    Andrew Beckett over 5 years ago in reply to srour
    Strange. I just tried to reproduce that, but couldn't - no matter what I did, the PostScript looked OK.
    Anyway, you have a workaround now, at least.
