  3. DRC DIVA. How can I solve this marker text: "Space to three...
  • Subscribers 133
  • Views 2942
DRC DIVA. How can I solve this marker text: "Space to three adjacent Contacts ( < 0.10um apart) >= 0.08 um"?
VictorArzate
VictorArzate over 5 years ago
I am designing a simple inverter to test the gpdk045 library, and when performing the DCR with DIVA, this appears: "Space to three adjacent Contacts (<0.10um apart)> = 0.08 um"? .
I generated the cells of the transitors as follows: Connectivity-> Generate -> All from source. And I generated a PMOS type transistor as seen in the attached image. I would like to solve this.
    I just tried this out with a pmos1v with finger width=400n and a "detached" Bodytie type, and the spacing of the contacts is 0.08um - this error didn't occur when I ran Diva (a little unusual to run Diva…
    I just tried this out with a pmos1v with finger width=400n and a "detached" Bodytie type, and the spacing of the contacts is 0.08um - this error didn't occur when I ran Diva (a little unusual to run Diva, but it is supported with this PDK).
    Which version of gpdk045 are you using? Which device is it that you have placed, and what are the parameters?
  • VictorArzate
    VictorArzate over 5 years ago in reply to Andrew Beckett
    Hi
    I'm using gpdk045_v_6_0 version. The device I placed is the pmos1v with finger width =360nm, "detached" Bodytie type, Lenght =45nm, Tap Contact Rows =1.  I attach an image.
    Andrew Beckett over 5 years ago in reply to VictorArzate
    OK - for some reason when I first played with this, I thought that 400nm was the minimum to get three contacts. With 360nm, I see the 0.06um spacing between the contacts.
    The issue however is that the Diva rule is not coded to find the spacing when there are greater than 3 neighbours (I don't think this is possible with Diva - at least not easily - and it's rule that typically only started to appear in smaller nodes that Diva is not typically used for). So the Diva rules are merely finding all the contact spacings less than 0.1um and then checking of those if any are less than 0.08um. In this example it's wrong because there are not 3 neighbours for any of the contacts.
    Put simply, I wouldn't use Diva on this PDK - use PVS (or Assura).
