  3. Automated way for creating custom layout cell view for polygon...
  • Views 13241
Automated way for creating custom layout cell view for polygon shapes
sidm
sidm over 5 years ago
Hi All
I need some advice on creating a layout cell view that has a 45 deg rotated square for multiple conductor layers in the PDK.
Can anyone please suggest an automated way to generate this shape for different layers ? (i have lot many layers).
I need to use IC617 Layout XL for this.
thanks
    This would be trivial with SKILL - draw the square once, rotate with the rotate command, and then select it. Then use code something like this:
    shape=car(geGetSelSet())
    foreach(layer list("M1" "M2" "M3" "M4" "M5") ; whatever you want
      newShape=dbCopyFig(shape shape~>cellView)
      newShape~>layerName=layer
  • sidm
    sidm over 5 years ago in reply to Andrew Beckett
    thank you very much Andrew, is there a way to pass coordinates to draw the square / rectangle instead of fixing the one time drawn square ?
    Andrew Beckett over 5 years ago in reply to sidm
    Yes - use dbCreatePolygon to create the shape.
  • sidm
    thank you very much Andrew.
