  3. Virtuoso Spice In Device Map property is not honored
  • Views 24129
Nader Fathy
Nader Fathy over 5 years ago
I have a spice netlist with multiple different resistors and I want to import it into Virtuoso by Spice-In from CIW (File > Import >Spice). A sample of my netlist is shown below:
R1 2 VDDESD 1.93853e+06 L=0.00253009 W=4.2e-07 $[PR] $X=69635 $Y=50840 $D=47
R2 TAVDD AVDD 0.00138889 L=0.00003009 W=1.8e-07 $[M2] $X=65635 $Y=40840 $D=47
R3 TAVDD AVDD 0.00138889 L=0.00003009 W=1.8e-07 $[M1] $X=65635 $Y=30840 $D=47
I have created a map file to match my PDK devices as shown below:
devSelect := resistor rphpoly
propMatch := PR
termOrder := PLUS MINUS
propMap := w w l l
addProp := model rppo1rpo
devSelect := resistor rm1
propMatch := M1
propMap := w w l l
addProp := model rm1
devSelect := resistor rm2
propMatch := M2
propMap := w w l l
addProp := model rm2
After I imported the netlist, I found that all resistors are mapped to "M2" metal resistor which is incorrect.
Did I do a mistake here in the settings? Is there a setting that I should be aware of to honor the device property?
Any help is much appreciated.
OS: Redhat 7
Virtuoso Version: IC6.1.8-64b.500.15
Kindest Regards,
Nader Fathy
    Nader, That's actually a CDL netlist (not SPICE). CDL is based on SPICE and has some info embedded in SPICE comments (so the $[M1] is what is called the subtype ). So you should import it as CDL, and…
    Andrew Beckett over 5 years ago in reply to Nader Fathy +1
    Hi Nader, The parameters with CDL import will be in upper case, so your propMap need some attention - you can see the unmapped parameters show up as user-defined properties on the instances. So (depending…
    Hi Nader, I suggest you contact customer support . In the TSMC PDK I looked at, that property is called HardCons and if I do: addProp: HardCons nil then it adds it as a string, not a boolean. You…
    Nader,
    That's actually a CDL netlist (not SPICE). CDL is based on SPICE and has some info embedded in SPICE comments (so the $[M1] is what is called the subtype). So you should import it as CDL, and then have your propMatch like this:
    propMatch := subtype PR
    propMatch := subtype M1
    propMatch := subtype M2
    That should then map the devices appropriately (I tested it).
  • Nader Fathy
    Nader Fathy over 5 years ago in reply to Andrew Beckett
    Thank you for trying this out. I tried your approach and it worked indeed (Using subtype + CDL). However, the properties of the device (W,L) are ignored and not passed to the schematic view; all devices have the PDK default values (resistors and MOSFET devices). Please note that I am enabling "Trigger CDF Parameter Callback" option.
    This is an example of my resistor and MOSFET map:
    propMap := w w l l
    devSelect := N nmos2v_mac
    propMatch := subtype N
    termOrder := D G S B
    propMap := w w l l
    addProp := model nch_mac
    And these are examples of the netlist passed to
    M47 VSSESD 1 VDDESD VSSESD N L=0.18U W=34.5U AD=1.656e-11 AS=1.6215e-11 PD=6.996e-05 PS=3.544e-05 NRD=0.013913 NRS=0.0136232 sa=4.392e-05 sb=4.8e-07 sca=0.122669 scb=8.20968e-08 scc=9.08179e-13 $X=3330 $Y=49630 $D=0
    Your help is greatly appreciated.
    Nader Sh.
    Hi Nader,
    The parameters with CDL import will be in upper case, so your propMap need some attention - you can see the unmapped parameters show up as user-defined properties on the instances. So (depending on the destination PDK), something like:
    propMap := W segW L segL R r
    propMap := W w L l
    are likely to be needed.
  • Nader Fathy
    Again thank you very much, indeed this was the problem and now it works fine. There is, however, one final problem I am facing when importing the netlist: I am getting the following errors in the CIW:
    *Error* w is below minimum - setting to min
    *Error* l is greater than max - setting to max
    After debugging, I found out that the resistors are limited to a specific W & L in the PDK because the switch "Hard_constrain" is checked by default. When "Trigger CDF Parameters Callback" is checked, the numbers set are limited to the PDK maximum. According to the PDK manuals: to allow the values of W,L in the netlist "Hard_constrain" switch must be turned off. Is there a way I can use Virtuoso Spice-In and configure this?
    This is my resistor causing the problem in the netlist:
    Many thanks for your help.
    Kindest Regards,
    Nader Sh.
    Hi Nader,
    I suggest you contact customer support. In the TSMC PDK I looked at, that property is called HardCons and if I do:
    then it adds it as a string, not a boolean. You then get warnings in the CIW. I found CCR 753150 asking for the ability to set properties of different types, but it's not been implemented.
    I think the only workaround right now is probably to write some SKILL code which post-processes the imported schematic, sets HardCons=nil on each instance and then calls the CDF callbacks - e.g. using How to call CDF callbacks procedurally from SKILL to update CDF parameters? (this is how you had to do it before the ability to trigger the CDF callbacks was added for SPICE IN).
  • Nader Fathy
    I followed your guidelines with SKILL scripts and it worked!
    Thank you very much for everything. Have a nice weekend.
    Kindest Regards,
    Nader Fathy
