  3. Using variables with spectrumMeas
  • Views 11624
Rob Gregoire
Rob Gregoire over 5 years ago
Hello -
Variables work with the spectrumMeas function except for the "number of samples" entry. It requires an actual integer number. Is there a work around?
For example, this works
spectrumMeas(VT("/DoutDecimal") VAR("Tstart") VAR("Tend") 2048 1 dF VAR("BW") "Hanning" 2 "sinad" )
This does NOT work (replaced 2048 with VAR("Npts")
spectrumMeas(VT("/DoutDecimal") VAR("Tstart") VAR("Tend") VAR("Npts") 1 dF VAR("BW") "Hanning" 2 "sinad" )
I'm using virtuoso sub-version IC6.1.8-64b.500.8
Tanks,
rg
